I want to use a RS232 output (Tx). With "Ext properties" I can set the baud rate etc. With the "connections" I should be able to choose the Tx-ouput pin. But I get the message "" This component does not have external conenctions".
(Flowcode 5, PIC16F1827)
What to do?
Kind regards
Jan Lichtenbelt
PS. My mouse arm has been disappeared. The solution was (afterwards) simple: Do not bend your neck towards the screen, but keep it straight!!!!
RS232 no external connections
- Jan Lichtenbelt
- Has thanked: 128 times
- Been thanked: 264 times
- Jan Lichtenbelt
Re: RS232 no external connections
I found the solution. I had to change to Software RS232 in stead of UART1.
Jan Lichtenbelt
Jan Lichtenbelt
