working with engine
brunosilva
working with engine
Post by brunosilva »
I wonder how do I work with motor.
I am using an engine, most can not make it rotate right.
The sequence it would appear that it would be
    1000
    0100
    0010
    0001
or
0001
0010
0100
1000
I am sending the code to help
thank you
motor.fcf
(7 KiB) Downloaded 281 times
Re: working with engine
Hi brunosilva,
Not sure what your asking?
I have modified your flowchart so you can alter direction and speed.
motor 2.fcf
(10 KiB) Downloaded 268 times
dazz
Has thanked: 474 times
Been thanked: 458 times
Post by dazz »
I would create 2 macros called left and right, and add your code to call each macro in turn, i've wrote a simple flowchart for you, to give you an idea, simulate it then click the switches on/off in turn
Sorry martin posted as i was replying, you now have a couple of different ways of doing things
Dazz
motor2.fcf
(13.23 KiB) Downloaded 271 times
brunosilva
Hi the code did not work with my engine he from one side to the other and does not spin.
when I'm configuring the engine appears
Phase Patterns
and a sequence
0001
0100
0010
1000
my engine and I need to rotate the
Phase Patterns
is
0001
0010
0100
1000
a red square appears in front I can configure to show me that kind of Phase Patterns
So it works as I do it utizando engine.
the model of my engine is 1.8 Stepper Motor SM-GP-B1N Torque: 70 oz
brunosilva
got it
thank you
