Help files for PWM module in Flowcode 3
xtdan
Post by xtdan »
I have just installed the update to version 3.2, and want to start looking at using the PWM module.
I tried looking up teh module in the help tab of Flowcode but could find no mention of it.
Obviously what I would like to know is: What am I doing wrong? And how can I access the hep file which is mentioned in another PWM thread?
Thanks in advance!!
To get to the PWM help file you must add the component into your program and then click on the component and go to the properties menu. Once inside there should be a help button which will take you to the help file.
If this does not work then the help file is located inside the Flowcode V3 folder and is called PWM.hlp
xtdan
Post by xtdan »
Many Thanks,
It is all clear now. I will have a go when the workload clears a bit and I can get on with the backburner project I need PWM for.
I dare say I will have some more questions thet have obvious answers when the problems can be stepped back from, so I look forward to posting again soon!
Once again amy thanks for the support.
