Single step
Please add any bug reports that require discussion here
Forum rules
Only bug reports will be considered here. General questions should not be posted in this forum.
wayne millard
Has thanked: 7 times
Been thanked: 12 times
Single step
Post by wayne millard »
Why doing single step it will not wait at delays but when running a simulation it will?
Wayne
JonnyW
Has thanked: 63 times
Been thanked: 290 times
Re: Single step
Post by JonnyW »
If you are single stepping it could wait at delays, but it was decided this isn't typically what you want - if you are manually stepping though a program then you are probably debugging so having to stop at, say, a 5 second delay as you step through could be a little annoying. I figure either delays are long enough to be annoying or short enough to be ignored.
If there is demand for waiting at delays while manually stepping through I can probably add it as an option.
Jonny
