4d Display Visi serial commands interface
Forum for Flowcode v6 beta users
acestu
Has thanked: 783 times
Been thanked: 223 times
Re: 4d Display Visi serial commands interface
Post by acestu »
Hi Benj,
Benj wrote:Thinking about this.
Visi interface is loaded onto the SD card in the 4D display and it would be a huge undertaking to try and replicate all of this functionality.
If I could figure out how to parse the .dat file and generate the correct visuals for the visi front end then it may not be too bad to add simulation too. Is what we have already enough to make it useable?
Yes this is a brilliant start, thank you so much for doing this it means that we can use the components on the display to control the host micro, using the display as a serial slave would be a great tool also , but I realize you have a lot to do yet....
Cheers and thanks again
Acestu :D
acestu
Post by acestu »
Hi Benj,
I have tried to get your Visi Demo chart going but to no avail, I am enclosing the 4D Workshop file that I am using which has just the 2 rocker switches, could you take a look at it please and see if anything is wrong, I have set events on both rocker switches to "Report Message"
Acestu
New-rocker.rar
(1009 Bytes) Downloaded 639 times
Acestu
Might be worth trying with the rockerswitch events set to none. With the event set to report the display will talk to the micro when the switch state changes. With the event set to none then you should be able to poll the state of the switch at your leisure.
Also worth checking the baud rate of the Flowcode component is set correctly looked like it should be 115200 rather then 9600.
acestu
Post by acestu »
Hi Benj,
Is there any chance you could post the 4D Workshop file that you used to setup the Visi-Demo that you did please...
Cheers
Acestu
acestu
Post by acestu »
I have been trying to get your Visi-Demo chart to work and noticed that the two commands for the rocker switch index 0 are the same, so is it not switching rocker 0 on and then switching it on again ?
(9.87 KiB) Downloaded 5633 times
cheers
Acestu
Yes whoops the second VisiWriteObject call should be 0,0 not 0,1.
Not actually tested the code on hardware but it should be ok, went through it quite carefully. If your still having problems I will dig through for my 4D display and see if I can help you debug.
acestu
Post by acestu »
Thank Benj,
I will have another look when I get home tonight, I could not find the baud rate on the component, so I thought I would try the TX/RX flasher but I could not get that working either...
cheers for now
Acestu
The component should default to 9600 baud but there is an issue with this as you need to call the init function to initialise the UART but this then assumes a old style display and ramps the UART speed up to a higher baud (57600 from memory). Not sure if the newer display supports this as is. Will probably end up seperating out the Visi stuff into a stand alone component so it's easier to determine if your drawing to the display or talking via the Visi interface.
acestu
Post by acestu »
Hi Benj,
These are the baud rates that the 4d displays support in 4D Workshop..
(6.45 KiB) Downloaded 5624 times
cheers
Acestu
Hi Stu,
New fully tested and working component now available from here: http://www.matrixmultimedia.com/mmforum ... 53&t=12734
acestu
Post by acestu »
Hi Benj,
Thanks for doing this so quickly, I know what I am doing all day sunday :lol: ..
Cheers
Acestu
Locked
