Function-component creation from C code
Please add any feature requests for Flowcode version 6 here
Forum rules
Only feature requests will be considered here. General questions should not be posted in this forum.
Mantas
Has thanked: 57 times
Been thanked: 27 times
Post by Mantas »
Would it be possible and how to implement the possibility to create new components, or functions directly from C code, and them have them as standard library, like for the example I did with the inverse sqrt() function? Instead of having them as macros? Or is this just a no brain'er? :roll:
Cheers,
Mantas
Science is my true religion.
Re: Function-component creation from C code
Hi Mantas,
The Embedded Macro and Hidden Embedded Macro options in the Interface manager are basically for this very purpose and allows us to build components which either call existing C functions without any additional overhead or to call code e.g. to read or write to an array as used in the DSP components.
Mantas
Post by Mantas »
Hi Benj,
Sorry for the stupid question, but where do I find this Interface manager? :oops:
Cheers,
Mantas
Hi Mantas,
I talk briefly about the interface manager in this vid.
http://www.matrixmultimedia.com/mmforum ... 58&t=12735
More info can be found in the Wiki but I have some writing on this section still to do so I could try and add to this extra info in later today.
JonnyW
Has thanked: 63 times
Been thanked: 290 times
Post by JonnyW »
Hi. Dave has produced a video on the interface manager here:
[/youtube]
Jonny
Mantas
Post by Mantas »
Hi Gents,
Could you create a video of showing how to create a component, or a function specifically from C code? I know there is a supplementary section in the settings manager an others, but this is still mind boggling for me :? What if a C code function to call has a pointer in the parameter section...you know some more complicated functions implementation done by you in a video would be very interested to see.
Thanks in advance! You are doing an amazing job there!
Best regards,
Mantas
JonnyW
Post by JonnyW »
Hi Mantas. Yes, it would certainly be possible to do a video on this.
As far as pointers go, we get around that when using DLLs by using an array of 1 element, but all macros must conform to Flowcodes procedure-call standard, that is that every array is followed by its size, and the return type (if a string) is the final argument. This is easily fixed with a #define though:
#define FlowcodeFunc(arrayptr, arraylen) RealFunc(arrayptr)
I've wanted to do a video on embedded component macros for a bit, so see if there is time today now I know there is demand.
Cheers,
Jonny
Mantas
Post by Mantas »
Hi Jonny,
I would really appreciate that! This would simplify a big part of my work were I need to convert C code to flowcode!
Cheers,
Mantas
JonnyW
Post by JonnyW »
Because we moved buildings the audio equipment is tucked away somewhere, but I have scripted a video and hopefully can roll that out when the box with the microphone us uncovered.
Jonny
