Training Video 37 Model
acestu
Has thanked: 783 times
Been thanked: 223 times
Post by acestu »
Just wondering if the guys at MM could tell me if the Mixer Model in training video 37 was made in Flowcode or imported from another 3d modelling program ?
(158.61 KiB) Downloaded 1489 times
The reason that I am asking is that if it was done in Flowcode then some sort of Boolean modelling must be possible to get the shapes ie the slider pot knobs..
Cheers
Acestu
JonnyW
Has thanked: 63 times
Been thanked: 290 times
Re: Training Video 37 Model
Post by JonnyW »
Hi.
The sliders will all be Flowcode components. Some will have meshes most likely done in Sketchup, and some things will be Flowcode primitives. The slider tops etc are meshes, I believe.
Flowcode can create dynamic models - see the point cloud stuff for this, but it would be far more trouble than its worth for this use. I know you have an issue with importing .obj files from some apps - that will be fixed in the next patch which hopefully will be pretty soon.
When creating a component if you add the meshes you want as resources they will be exported along with the component so it is only one file.
Jonny
