Hello Matrix,
Have you considered making an interface PCB that will allow the user to mix and match the connections to an E-Block? This is useful when developing a idea but do not want to use the default E-Block connections.
I imagined something similar to what you have done on the EB005 board, only this board will be 2 ports wide and fit your development board.
Best Regards
Richard Hogan.
Interface Board
- JohnCrow
- Has thanked: 364 times
- Been thanked: 716 times
Re: Interface Board
Hi Richard
Have you looked at the EB017 protoboard.
These are 2 ports wide, and very useful. Ive used these for several projects.
I built a multi sensor board using this, and also used it to design my own eblocks.
http://www.matrixmultimedia.com/mmforum ... f=2&t=7940
