I have several programmers, It looks like you can set Flowcode to switch between them as required.
The programmers I have is as follows
PicKit2, PIC, DsPIC
PicKit3, PIC, DsPIC
E-blocks EB006, PIC
E-blocks EB031, ARM
Microchip Explrorer 16, DsPIC
Has anyone got the settings for the above programmers, I have managed to get the latest settings for the PikKit's, and would it be a good idea to put all the latest settings for different programmers in one place, maybe help to make things a bit easier to find
Programmers
- Has thanked: 5 times
- Been thanked: 6 times
- Has thanked: 1 time
- Been thanked: 26 times
Re: Programmers
Hi JFinlayson
Download and install the MPLAB 8.92 ! (not the mplabx)
After open the mplab as blank goto > Configure and select > device > your pic
>open programmer and select your type of prog.
It must Show the Output window
Then open File > Import > the **.exe in your flocode Folder
You can schow in the Output / Build window the hex file and in the MPLAB ICD3 window the connect info
z.b:
MPLAB ICD 3 detected
Connecting to MPLAB ICD 3...
Running self test...
Self test completed
Firmware Suite Version...... 01.28.90
Firmware type......................PIC32MX
MPLAB ICD 3 Connected.
Target Detected
Device ID Revision = 34300053
>after click program:
Self test completed
Target Detected
Programming...
Programming/Verify complete
If you take a new compile inside flowcode the window Change automatically to the build-window (not so in the new mplabx)
(so you have a control over the right *.hex file...)
> click program again......
have a good work
Regards Wolfgang
z.b:
Self test completed
Target Detected
Self test completed
Target Detected
Programming...
have a good work
Regards Wolfgang
Re: Programmers
Thanks for the above.
One other question, will there be support within Flowcode 6 for PIC32 devices?
The older the boy the bigger the toy
