pattern on
saschech@gmx.de
- Has thanked: 1 time
- Been thanked: 26 times
pattern on
I have no Background pattern und only French and german language
Regards Wolfgang
Regards Wolfgang
- (26.75 KiB) Downloaded 973 times
- (23.96 KiB) Downloaded 973 times
- JonnyW
- Has thanked: 63 times
- Been thanked: 290 times
Re: pattern on
Hi Wolfgang.
We have yet to release the other languages, but this should be done quite soon (hopefully). We may release them incomplete in order for users to at least get some translation done. Most are about 75% complete or above.
For the patterns, this is because you have a white pattern on a white background. This has caught a few people out, actually, and I will change how this displays, but if you change the background colour from white you should see the patterns.
Jonny
Jonny
saschech@gmx.de
Re: pattern on
Hello Jonny
Ok I can Show the pattern,bat never bevor I Change it.....
Is there a way,set the symbols correkt "on the lines" because it is not nicely for my eye`s Show 3 lines
If open with ms-Paint Show it "perfekt"
Thanks and regards wolfgang
- lines.jpg (165.81 KiB) Viewed 8500 times
saschech@gmx.de
- JonnyW
Re: pattern on
Hi Wolfgang.
Sorry, I don't follow - can you show me the MsPaint perfect version so I can see the difference?
I agree with the pattern it is not nice on the eye - this is the reason it is turned off by default in v6.
Jonny
Jonny
saschech@gmx.de
Re: pattern on
Hello Jonny
I think thera are a "misunderstanding",
I mean ,with Ms-paint you can see the 3 lines better ;sorry.
Regards Wolfgang
Regards Wolfgang
- DavidA
- Has thanked: 58 times
- Been thanked: 258 times
Re: pattern on
Hi Wolfgang,
We cant seem to see a problem with the screenshot you are showing us, do you have one which highlights the problem?
saschech@gmx.de
Re: pattern on
Hi David
Please have a look again.I finger up to 4 lines....
Regards Wolfgang
Regards Wolfgang
- lines.rar
- (101.19 KiB) Downloaded 338 times
Re: pattern on
Hello guys,
Wolfgang is talking about shadows.
So he got the grid on and it shows the flowcharts shadows.
If he zoom in the flowchart it's better to note it, instead the default zoom level.
Cheers!
Cheers!
- Shadows.rar
- (166.52 KiB) Downloaded 270 times
- JonnyW
Re: pattern on
This graphics spec will remove shadows. If you add it in your <instal_directory>\GFX folder then click global options you should see it in the lists. Select this and shadows are removed. Let me know if there are any problems with this.
Cheers,
Jonny
Cheers,
Jonny
saschech@gmx.de
Re: pattern on
Hello Jonny
It Looks mutch better!,but grid and symbols,lines are not 100% agreeing....
Thanks and regards Wolfgang
