Hello guys!
I just assembled a K8055 Velleman kit.
I have a led on the dashboard that i want to show the status of Input1 of the kit.
Is there a way to turn on the led without going through the simulated device?
Is there any property that can be exposed so that i avoid the calculation box?
Is there any such property of the led or something?
Thank you in advance.
Flowcode 6.0.3.0 + K8055D
Tom Stefanou
- Has thanked: 7 times
- Been thanked: 7 times
Re: Flowcode 6.0.3.0 + K8055D
Hi Tom,
Not sure what you mean by these Tom, which simulated device? could you elaborate?Is there a way to turn on the led without going through the simulated device?
Tom Stefanou
Instead of creating a variable and moving the value to this variable and then assigning it to the led i read the status from the 8055 input directly to PORTB$.0
Thank you Benj for making me see the answer...
