Article: https://www.flowcode.co.uk/old_site/resources/get ... php?id=378
If you have any questions for the author or comments on the article, please post them below.
MX014 - Speaking Volt Meter
Re: MX014 - Speaking Volt Meter
I tried to make Speaking Volt Meter with FC 5.5.2.1 and using a PIC. Appendix is my tryout which doesn’t work. I don’t understand how to do this mentioned in description:
jjw
Thanks Benj great article. Thanks for sharing it.Note if you are using a PIC then you will have t use the conversion function from the calculation icon properties.
jjw
- Speaking Volt Meter.fcf
- (31.48 KiB) Downloaded 978 times
Hi Jukka,
I believe Ben is referring to conversion of Floats to bytes. (float2Int function)
If that is the case then on the calculation box you will see icons labeled 'fx' and 'f$'
Just click 'fx' and select float2Int function.
If your project is not working, can you give more details of what aspect is not working?
