50Hz PWM
saad.sharif
Has thanked: 4 times
Been thanked: 1 time
50Hz PWM
Post by saad.sharif »
please any one can tell me how to make 50 Hz with pwm in flowcode.... i am using 4MHZ crystal please kindly tell... i shall be very thankful to you.....
Re: 50Hz PWM
I moved the post as it seems to be relating to a new topic.
Which version of Flowcode are you using? I think the Hardware PWM will not run this slow but it should be possible using a timer based software driven PWM.
saad.sharif
Re: 50Hz PWM
HELLO
i am using flowcode version 5.1...
brandonb
Has thanked: 175 times
Been thanked: 173 times
Re: 50Hz PWM
Post by brandonb »
you'll have to set if up for your chip, and change c code to
t2con=4; pr2=199;
YOUR PWM.fcf
(13.23 KiB) Downloaded 841 times
saad.sharif
Re: 50Hz PWM
HELLO
sir i am having 4 MHZ crystal and 16f887 pic micro controller... plz can u draw it with my requirements please...
i shall b thank full to you..
saad.sharif
Re: 50Hz PWM
hello brandonb
it is not working ....
brandonb
Re: 50Hz PWM
Post by brandonb »
here you are, this is a 50hz pwm 0-100% sweep program set up for your chip
YOUR PWM.fcf
(9.5 KiB) Downloaded 894 times
cheers
saad.sharif
Re: 50Hz PWM
hello
sir if i want to add adc with 0-100% sweep .... please can you do it for me....
and thanks for the 50 hz...
saad shaarif
saad.sharif
Re: 50Hz PWM
hello mr brandonb,
sorry for disturbing you again again... sir i want to to out puts.. which work one by one for example if port A5 is 1 then port A2 is 0 and when port A5 is 0 then port A2 is 1... in this way i want 50 hz... and duty cycle must same on both ports...
please can u draw it for me....
and i have added adc to your pwm that you uploaded it i just want to see how you add adc with it...
saad sharif..
have a nice day sir..!
brandonb
Re: 50Hz PWM
Post by brandonb »
when i get off work will get that done for you
saad.sharif
Re: 50Hz PWM
Hello brandonb,
please kindly help me i am waiting...... is there any problem for you to do....
saad sharif
have a nice day..!
Re: 50Hz PWM
Hi saad ,
All you will need to do is use an ADC component (ReadAsByte)
use a formula to convert from 0 - 255 to 0 - 100
assigned the result to a variable called pwm.
Finally delete
pwm = pwm + 1
calculation box.
Then you will have a pwm duty thats will be controlled by ADC pot.
Can you please give it a go, then if your stuck, you can post flowchart for further assistance.
saad.sharif
Re: 50Hz PWM
HI MARTIN
i have done it as you told.. but i want two outputs of 50 hz pwm with the same duty cycle on both ports..
can you help me for that.
saad sharif
have a nice day.!
Re: 50Hz PWM
If you post a flowchart, with your modifications, what you want can be easily modified for you.
saad.sharif
Re: 50Hz PWM
Here is it...
50 Hz PWM with ADC.fcf
(16 KiB) Downloaded 580 times
Re: 50Hz PWM
Hi saad.sharif,
You can try this Flowchart
50 Hz PWM with ADC V2.fcf
(12 KiB) Downloaded 613 times
