How do I make a AM , PM clock
VirusAlert
Post by VirusAlert »
any ideas?
Has thanked: 114 times
Been thanked: 422 times
Post by Steve »
Use the TIMER0 interrupt with a suitable crystal clock frequency and prescaler. Update the timer info in the TIMER0 macro, and repeatedly display the time within your main routine.
rrwoods1978
Post by rrwoods1978 »
Can we get that in English please? If we don't even know how to make a clock, then I am thinking we are pretty new to this.
I need to make a standard 12 hour clock with am & pm functions and alam. Also need a way to set the time and alarm using the switch board.
Ian
Been thanked: 1 time
Post by Ian »
The Timer macro is called at so many times a second e.g 75 times a second or 75Hz.
The prescaler and crystal clock frequency allow you to set the refresh rate to a useable time period such as 75hz that you use.
Count to 75 in the timer interrupt macro and a second has passed.
Update the seconds minutes hours etc. .
The main program can display the time and check for inputs.
12 or 24 hour clock is simply a way to display the 24 hours.
