Does the latest version of FC5 still need Hi-Tech C to compile pic 18f46j50 code or will the standard boost c do the trick?
What compiler to use
Re: What compiler to use
Hi Desdewit,
SimPLC RTCC V1.0a.fcf (using 18F46J50) compiles with Flowocde V5.5.2.1 and boost C without any errors.
Not got the hardware to test with.
Desdewit
- Has thanked: 25 times
- Been thanked: 11 times
Hallo Martin
Thanks for checking.
My version isV5.5.0.1 (22.01.13) but when I check for updates the program respond with "Your version of Flowcode_PIC is up to date".
How can I update to V5.5.2.1?
Hi Desdewit,
If you go to:
http://www.matrixmultimedia.com/flowcod ... nloads.php
You will have to enter the last two sections of your license key including the dash.
That should allow you to download the latest version.
If you go to:
