TMR0 INTERRUPTION PLUS PWM ECIO40
Please add any bug reports that require discussion here
Forum rules
Only bug reports will be considered here. General questions should not be posted in this forum.
ALOPEZ
Been thanked: 1 time
Post by ALOPEZ »
I'm trying to use timer int plus pwm. In simulaiton works fine, but in hardware just work int or pwm if i try at same time doesn't work.
please i need help. PLease find attach project.
thanks
pwm.fcfx
(8.51 KiB) Downloaded 437 times
Re: TMR0 INTERRUPTION PLUS PWM ECIO40
Please can you give this a go and see if it's any better, Timer 0 and PWM should work ok together. The ICD setting in the debug menu was switched on which means the hardware would sit and wait for input from an ICD tool when you compile to the device.
pwm.fcfx
(8.5 KiB) Downloaded 443 times
ALOPEZ
Post by ALOPEZ »
thanks Benj, but I can't open your file. please see file attach with a printed screen.thanks
(154.42 KiB) Downloaded 975 times
