version 2 analogue and digital sensors
ukweb
Post by ukweb »
1. Can i know about the analogue and digital sensors on matrix multimedia v2 board. Can they be used to send and receive data. If yes, how could they be accessed by writing a C code.
2.Is it possible to connect to a xm10u (x10 block) through any of these sensors.
I think as the xm10u modulates and demodulates the signals, it could be accessed via the digital sensor.
ukweb
Has thanked: 114 times
Been thanked: 422 times
Post by Steve »
I presume you are asking about the 2 white "BT" sockets. I wouldn't recomment using them for anything other than the range of sensors we supply. The pin-outs are shown in the circuit diagram for the board (probably on the ELSAM CD) if you're really interested.
I would suggest you used the screw terminal blocks available for ports A and B to connect to the X10 transceiver, or use the terminal block headers to connect to ports C / D (if you are using a 28 / 40-pin chip).
You may need some additional protection circuitry to avoid damage to the PIC when using this transceiver (our E-Block module provides this protection).
I hope this info is useful.
