Help With Temperature
Bobw
- Has thanked: 6 times
- Been thanked: 27 times
I am trying to display temperature in degrees Fahrenheit.
I am using the following sensor :
http://ww1.microchip.com/downloads/en/D ... 21942e.pdf
I am also using a 16F1827
I am able to read the sensor no problem.
I am using an example that John Crow (thanks John) had posted http://www.matrixmultimedia.com/mmforum ... 445#p49124
This work fine but I am lost as to how to convert it to one decimal place and display in degrees Fahrenheit.
Bobw
Re: Help With Temperature
Guess I can not compile it to hex
get the following errors
FCD_ADC1_ADC_RAW_Average_Channel_Byte in: C:\Users\Bob-Notebook\Documents\FlowCode\newhum5.c
FCD_ADC1_ADC_RAW_Average_Channel_Int in: C:\Users\Bob-Notebook\Documents\FlowCode\newhum5.c
FCD_ADC1_ADC_RAW_Disable_Channel in: C:\Users\Bob-Notebook\Documents\FlowCode\newhum5.c
License restricted by the following files:
C:\Program Files (x86)\Flowcode\v5\Tools\BoostC\lib/libc.pic16.lib C:\Program Files (x86)\Flowcode\v5\Tools\BoostC\lib/libc.pic16.lib C:\Program Files (x86)\Flowcode\v5\Tools\BoostC\lib/libc.pic16.lib C:\Program Files (x86)\Flowcode\v5\Tools\BoostC\lib/libc.pic16.lib C:\Program Files (x86)\Flowcode\v5\Tools\BoostC\lib/libc.pic16.lib C:\Program Files (x86)\Flowcode\v5\Tools\BoostC\lib/libc.pic16.lib C:\Program Files (x86)\Flowcode\v5\Tools\BoostC\lib/libc.pic16.lib C:\Program Files (x86)\Flowcode\v5\Tools\BoostC\lib/libc.pic16.lib C:\Program Files (x86)\Flowcode\v5\Tools\BoostC\lib/rand.pic16.lib C:\Program Files (x86)\Flowcode\v5\Tools\BoostC\lib/float.pic16.lib newhum5.objRecompile the code with a less restrictive compiler license!
License exceeded by RAM: 0 bytes
License exceeded by ROM: 690 words
You have reached the limit of the Standard License
PIC12,PIC16 max code size:4096 words, max RAM banks:Unlimited, Non commercial use only
You can upgrade your license. Please visit: http://www.sourceboost.com
failure
Return code = -2
Flowcode was unable to assemble the ASM file due to the following errors:
Guess I need a new license
failure
Return code = -2
What license type are you currently working with? Is it the home/student version?
I think you can either pay the difference to upgrade to pro or upgrade to a v6 license.
Bobw
I am using the home student version.
I read in other post where floats take up a lot of ROM, did not realize it was that memory hungry.
May just leave it at whole numbers.
Have attached what I have so far using whole numbers.
It works great for Humidity. My temperature calculations are off.
I have it in a loop to just get the temperature working before I move on to the rest.
Humidity appears to be right on with my calibrated humidity device I have. The sensor I use is very sensitive, just breath on it and it will read a change.
Bob
Bob
- newhum44.fcf
- (15.2 KiB) Downloaded 404 times
Bobw
After reading more on floats, I think I will use the LEFT and RIGHT function to get the results I need.
I am not sure how to set the ADC to read the 10 bit resolution (0-1023) or 0.004883 MV per step.
Do I have to use the VREF pin of the PIC by connecting +5 volts to it, or is that done internally?
I know that 10MV from the temp sensor=1 degree C.
Using Voltage in/0.01 should give me a digital reading *0.4883 = tempC
I am lost as the the variables I need to set, and should they be float values or integers?
Bobw
Thanks to this post:
http://www.matrixmultimedia.com/mmforum ... 523#p56523
I have it figured out and working.
For those also building projects, do read other post, down load the included charts. It took me looking at 3 other examples before I understood how the LEFT and RIGHT commands worked, how to properly read the ADC value and figure how it relates to temperature change (Have DATA sheet handy)
I am glad someone did not just make it work for me, but that I understand how it works.
Yes I copied the code that Bill and Martin used, but I understand the inner workings of it which is even better.
It is a real winner work around as opposed to using memory intensive FLOATS.
I am worried it wont display a negative temperature, but will see when I stick the probe in my freezer (should be -1 to -5 F).
Thanks to all on this board for all the help over the years.
Bob
Bob
Hi Bob,
Glad you have got your flowchart working and one of my flowcharts contributed to helping you..
Thanks for letting us know
Matin
I totally agree with that.Bobw wrote:For those also building projects, do read other post, down load the included charts.
I also agree with that as I believe you learn far more by studying other flowcharts than saying can you create a chart for me.Bobw wrote:I am glad someone did not just make it work for me, but that I understand how it works.
Matin
Bobw
I think my calculations may be still off.
My temp sensor can go from -40C to +125C or 10.0mv per degree C. (yes I am using Fahrenheit but can convert it all later)
That would = 165 steps.
If I read the ADC as an int. I can get 1024 steps (0-1023)
If I divide the ADC value(1024) by the sensor steps (165) this should give me 6.206 or an increase in ADC value of 6.206 per each degree of temperature increase.
Two questions:
1) is my basic math correct?
2) How should I adjust so that I could show a negative temperature?
I am using this equation to start:
Fahrenheit = ReadADC * 49 / 10
I have it figured out how to display a decimal number without the floats. And I can easily convert C to F later.
Two questions:
Hi Bob.
I have worked out a formula that hopefully should convert an integer directly into Fahrenheit * 10
So you can try:
Fahrenheit = ADC*88/10-576
Hopefully this should read temperature from -40F to +257F with greatest error in some places of +/- 4.4F
It's just a starting place until a better formula is found.
Note Minimum ADC = 20 = -40F
Max = 358 = 257F
So you can try:
Max = 358 = 257F
Bobw
Martin,
Thank you will give it a go.
I do have a question about ADC VOLTAGE. If you try to read ADC voltage in the Simulator, it only displays whole numbers. 0 volts to 5 volts.
I am hoping that in real life it will read 1024 steps (10 bit) of 0.0048828125 volts per step up to 5 volts.
Should have bought a Fahrenheit sensor, would have save some head aches.
Hi Bob,
With int and bytes there are only whole numbers.
So what the formula does is take the value of ADC = 0 to 1023 and converts it to Fahrenheit * 10 as stated on my previous post.
What you need to get the flowchart to do is precede the last number with a decimal point i.e: I modified the flowchart posted here:
http://www.matrixmultimedia.com/mmforum ... 523#p53142
With the revised formula.
Note ADC 40 = 195 mV
Bobw
Martin,
Your formula works great!!!! Appears to be about +- .3 degrees compared with a calibrated thermometer I have here.
If I could ask you to break down your formula so I can make sure I understand the actual numbers.
What does the 88/10-576 all stand for?
I think a basic mistake I was making was thinking that at the lowest reading of my sensor -40C the ADC would be at Zero (not True), and at the highest +150C it would be 1023 (not true).
I also failed to take into consideration that while the PIC does not deal with decimals well, it will deal with them if you increase their value to a higher number (Val*100).
I see many temperature related post on here, I have been taking notes and think I will try to write a tutorial for others when I am done. Most like myself get lost in the formulas verses the actual use of FLOWCODE.
I can see where floats may provide a bit more accuracy if needed, but using the LEFT,RIGHT string manipulation works just as well with much less memory loss.
Bob
Bob
Hi Bob,
Thanks for that as I was not expecting it to work that well to be honest.
This all relates to MCP9700/9700A and displaying results in deg Fahrenheit:
First I looked at the data sheet and it stated that voltage changes by 10mV per deg C and the offset is 500mV.
So at 0 deg C the Voltage out will be 0*0.010+0.5
Next I created a spread sheet and placed a 0 in column A, then you can see what I did in all the other columns: Then I got column A to increment by 1 going below the 0 and decrement by 1 going above the 0, then dragged all the cell formulas to fill all the blank cells up to -40C and down to 125 since
Next I opened my Formula Generator which Can be found here:
http://www.matrixmultimedia.com/mmforum ... 99&#p13504
Entered the following data from the top row: And the data from the last row: Into my Formula generator: Now a bit of PIC integer knowledge is handy.
For example since the maximum integer number is 32767 you can't exceed this within a calculation
Since the highest value for ADC is 358 then you can't use 358 * 879 since 314682 is greater than 32767.
The way around this is use 358*88
Now you know where ADC * 88 comes from.
the 10 is used because it was originally /100 but we have multiplied by 88 instead of 879.
Final part on the formula generator is -28787/50
I just broke that down a bit more by:
28787/50 = 575.75
I just rounded it up to 576.
Putting it all together:
88/10-576
Wow!Bobw wrote:Your formula works great!!!! Appears to be about +- .3 degrees compared with a calibrated thermometer I have here.
No problem, I can post step by step so you can see how I derived atBobw wrote:If I could ask you to break down your formula so I can make sure I understand the actual numbers.
88/10-576First I looked at the data sheet and it stated that voltage changes by 10mV per deg C and the offset is 500mV.
28787/50 = 575.75
88/10-576
