16f876 28 pin connecting x10
ukweb
Post by ukweb »
The previous post response was as follows:
( I would suggest you used the screw terminal blocks available for ports A and B to connect to the X10 transceiver, or use the terminal block headers to connect to ports C / D (if you are using a 28 / 40-pin chip). )
So by using a 28 pin (16f876) -- matrix multimedia board v2 to connect to the x10 transceiver (xm10u) .
Where are the terminal block headers, i cant spot them on the board v2, are the terminal block headers mentioned on the data sheet. Please let me know.
thanks
ukweb
Has thanked: 114 times
Been thanked: 422 times
Post by Steve »
The screw terminals on the v2 board are located at either side of the board, just above the sensor sockets - portA to the left and portB to the right.
If you are using an '876 I would suggest using portC via the 40-way expansion header. This header is next to the DIL socket for 40-pin PICmicros. It's pin-out replicates the 40-pin chip, so look at the datasheet for an '877 (or similar) to find where portC is located.
Note that on some boards, we did not actually fit this 40-way header, but the holes will be there and you should be able to solder directly to them.
