Dear,
The PWM component is no longer located in the components of flow code version 6.0.7 menu.
Best regards
Nazaire
PWM component in flowcode V 6.0.7
Nazaire VERRUE
- Been thanked: 3 times
Re: PWM component in flowcode V 6.0.7
The PWM component has been removed from the main component headings, it is available via the search item and you can add it to the favorites list if it is a commonly used component you want to be able to easily access.
