Oefening33.fcfx in the Miac module would not work
Nazaire VERRUE
Been thanked: 3 times
Post by Nazaire VERRUE »
Dear,
The oefening33.fcfx (see attachment) works perfectly in simulation.
When I load the oefening33.fcfx in the Miac module then would not work.
However, when compiling one gets no mistake.
What's wrong here?
Sincerely
Nazaire
Oefening33.fcfx
(10.04 KiB) Downloaded 398 times
Last edited by Nazaire VERRUE on Thu Apr 10, 2014 8:33 pm, edited 1 time in total.
Re: Oefening33.fcfx in the Miac module would not work
I've had a look at your program and can't spot anything that would potentially cause an issue.
Are you getting anything on the LCD on the MIAC when you load the program?
Have you tried a very basic program to print a string to the display?
Finally, what version of Flowcode 6 are you using?
Nazaire VERRUE
Best Benj,
On the LCD I get a zero when I load the program instead of 422.
I have a string printed on the display in the simulation and this works correctly.
I use flow code V6.07.
Greetings.
Nazaire
Nazaire VERRUE
I found the problem. Namely the variable Char [1] should Char [2] and the variable StringRest [10], StringRest [2] and the variable StringData [10], StringData [11].
Now it works correct.
Greets,
Nazaire
