On the 18F46K22 Channel2 does not seem to output on C1, it outputs fine on the alternative of B3.
Channel 1 works fine on C2.
Channel 3 works fine on B5, not sure about E0.
I have tried the solution of Jan at
http://wwww.matrixmultimedia.com/mmforu ... 54&t=14564
but with no success.
Thanks in advance,
18F46K22 Channel 2 PWM pin option not working
Mark
- Has thanked: 20 times
- Been thanked: 16 times
Re: 18F46K22 Channel 2 PWM pin option not working
Some input on this one would be appreciated.
If nothing else, where can I find the set-up code so I can see what values are being placed in the registers?
Go with the Flow.
- LeighM
- Has thanked: 481 times
- Been thanked: 699 times
If you look at the generated C code for your project, you will see the definitions such as
The PWM setup code is in the file PIC_CAL_PWM.c found in the Flowcode installation directory ..\CAL\PIC
#define MX_PWM_REF1
#define MX_PWM_PRESCALE1 (1024)
#define MX_PWM_PIN_1 (1)
#define MX_PWM_PORT_1 portc
#define MX_PWM_PERIOD 255
#define MX_PWM_TRIS_1 trisc
#define MX_PWM_CHANNEL_1 (2)
Mark
Thanks, I will have a look.
The 18F46K22 timer 2 setup also does not work properly, it shows two prescalers but only one prescaler works (evidenced by the interrupt generated being way too fast). I used timer 6 instead and this works correctly.
Mark
Mark
Go with the Flow.
