so my next future request will be ...
a check box at icons for set it active/passive in Flowcharts
so user can test more possibles without deletings allways ICONS and then again make new with all parameters....
example with this checkbox option :
checked as False: FC simultan "delete" all what FC maked if ICON append.. .( Settings in C Code Window too! ( USBINT0 ) )
as True.. FC set all code to this ICON and the ICON is activ...
TY
Rudi
active/passiv setting to ICON.s in Flowchart
Forum rules
Only feature requests will be considered here. General questions should not be posted in this forum.
kersing
- Has thanked: 553 times
- Been thanked: 1081 times
Re: active/passiv setting to ICON.s in Flowchart
This feature is already available, right click on an icon for the menu, then select "Disable icon". The icon will be "grayed" out.
― C.S. Lewis
― C.S. Lewis
is this funtionally with the INTERUPT ICON likewise USBINT0 ?kersing wrote:This feature is already available, right click on an icon for the menu, then select "Disable icon". The icon will be "grayed" out.
kersing
Have you tested it?
― C.S. Lewis
― C.S. Lewis
Jac, you're not sure, or why do you ask?kersing wrote:Have you tested it?
...the "released" 6.0.7 that is a Patch...
- i must reactivate ???...
and then .. my Profissional is a Home Version - without Chippacks...
i will finnish my Explore with FC Jac, sorry.
Rudi
edit this because i give FC a last chance .. but also after 12 try's and reinstall..
Home Version
shame about the wasted time
.....prefer an end with fright ...
than a fright without end.
kersing
I'm sure as I've used the feature many times. But I also think you get more familiar with Flowcode by trying things yourself when pointed in the right direction. Sorry to read about your upgrade issues, I ran the upgrade on two computers without any issues.
― C.S. Lewis
― C.S. Lewis
