Problems with analog simulation using arduino mega 2560
outlawstc
Has thanked: 12 times
Been thanked: 9 times
Post by outlawstc »
I am having problems with simulating the arduino mega 2560 analog channels..
I set it up with the regular potentiometer set to channel 0
Then i make a int called Pot1
I use the Getint macro
The simulation debugger will only return 0 at any setting of the simulated pot
I open op the Analog input window and it will return byte, percent and Uint values but will not return a Raw
I change my target chip to arduino uno pdip and all works well.
I have not seen how it reacts on the real micro put i would assume if the simulation has a problem most likely the real chip will to.. plus its not very helpful with testing and debugging when its not working in sim.
Br,
Slade
"If your having code problems I feel bad for you son... I got 99 problems but a glitch ain't one"
outlawstc
Re: Problems with analog simulation using arduino mega 2560
Post by outlawstc »
This is a software bug and not a bug in my flowchart
outlawstc
Post by outlawstc »
This problem occurs with the arduino1280 , arduino mega 2560 adk, and arduino mega 2560 from the ones i have checked... A simple way to work around this for now is to select the chips from the AVR atmega list and not the arduino list.
LeighM
Has thanked: 481 times
Been thanked: 699 times
Post by LeighM »
Thanks. I've logged the bug for fixing asap.
Leigh
