atmega328 Fuses
outlawstc
Has thanked: 12 times
Been thanked: 9 times
atmega328 Fuses
Post by outlawstc »
I have a arduino uno which im wanting to be able to apply the CLKO with..
Ive learned that the project options/ configure tab when the target is the arduino uno PDIP does not offer any option for changing things such as fuse settings..
Also i have learned that When selecting the atmega 328p target I have the option of doing a internal divide by 8 for the crystal freq as well as enabling the CLKO (clock out on portB 0)
When i select enable there is no effect with the up loaded code.. I do not get the signal on at port B0
I have also discovered I have a generic arduino uno that only has a 8mhz crystal installed and not a 16mhz!! just thought i would mention that for other that may find themselves having communication problems with serial applications!
"If your having code problems I feel bad for you son... I got 99 problems but a glitch ain't one"
