How to set different delay for multiple outputs at same time
Renjith
Has thanked: 2 times
Been thanked: 1 time
Post by Renjith »
Hi all,
How can I set different delay for 2 or more outputs at same time in flowcode.
Example:
LED1 On and Off every 100ms Delay
LED2 On and Off every 200ms Delay
LED2 On and Off every 300ms Delay
Renjith.
Re: How to set different delay for multiple outputs at same
You can use a timer interrupt to do that.
If you can post a flowchart with your target device selected, then I can modify it to work for you.
You will need to check all configuration settings are correct.
Perhaps a starting place would be to click on my signature link.
If you get stuck then state what version of flowcode you're running (Help About Flowcode).
We can then assist you further.
Renjith
Post by Renjith »
Thanks for your prompt replay and advice.
I am just beginner in microcontroller not a licensed user, I need to create some delayed outputs controlled by separate potentiometers, attached herewith the flowcode file which I try to simulate and fail. I hope you understand my requirement. by the way i am working on an another small project use 7 segment display and keypad will post it later for your kind review, please let me know the contact details of Matrix dealer in india for buy some E-Blocks for realise it.
Your kind response is highly appreciated .....
Renjith.
Flowcode1.fcfx
(11.19 KiB) Downloaded 251 times
Sorry,
did not see this post until now.
Will post something soon.
For International dealers take a look Here
Hi Renjith,
Here is a version which controls all three outputs independently of each other using a timer interrupt.
It can be done with loops but with interrupts may work better?
Delays V2.fcfx
(14.5 KiB) Downloaded 286 times
Renjith
Post by Renjith »
Thanks Martin.. Great idia
Renjith.
You're welcome.
Just need to bare in mind the simulation times are either much slower or much faster than hardware. It just depends on simulation speed settings
