Hello Fellows!
I'm trying to control a stepper drive, which usually accept standard STEP/DIR inputs.
I know Flowcode has this object http://www.matrixtsl.com/wiki/index.php ... ator_(DSP)
but this frequency generator is missing the ramp feature that would be needed for acceleration/decceleration moments.
The stepper motor component of Flowcode also doesn't have this kind of output scheme, which is really a very basic standard in the motion industry.
Maybe someone can guide me through the process.
Cheers!!
Step/Dir - Pulse Train Output with ramp generator
- Has thanked: 460 times
- Been thanked: 523 times
Re: Step/Dir - Pulse Train Output with ramp generator
Hello Organetic
maybe this worth a look , the part on generating a ramp from a pulse train (page 6) you could you the pic to generate the square wave
http://www.egr.msu.edu/classes/ece480/c ... 0Young.pdf
or you could you a op amp integrator circuit
