problem in accessing registers of DS1307
waleedabbasi12
- Has thanked: 4 times
Is there any way i can access registers of rtc DS1307 in flowcode macros.
- JohnCrow
- Has thanked: 364 times
- Been thanked: 716 times
Re: problem in accessing registers of DS1307
The DS1307 uses the I2C bus
This is only available in the Pro version of Flowcode.
I have posted some example programs in the past for FC5 using this. Do a search on the forums.
Now the easiest way to use it is with the DS1307 component posted by Jordy.
http://www.flowcode.co.uk/mmforums/viewt ... 307#p51810
Again, it will only work in the Pro Version as it still uses the I2C bus in within the component.
waleedabbasi12
Thank you John. I have read that post by Jordy, its quite helpful. But there is still one problem. I dont understand how to read time from DS1307. It always gives the time which i write on it. I mean the clock doesnot tick.
- JohnCrow
Have you got it connected correctly.
Have a look at the circuit in my tutorial post for an example.
http://www.flowcode.co.uk/mmforums/viewt ... 307#p25768
If you want to post your flowchart on here we can have a look see if we can help
waleedabbasi12
- JohnCrow
Glad you've got it working
Thanks for letting us know
