Add Close to File API
Please add any feature requests for Flowcode version 6 here
Forum rules
Only feature requests will be considered here. General questions should not be posted in this forum.
kersing
Has thanked: 553 times
Been thanked: 1081 times
Post by kersing »
The File API currently has no explicit option to close an open file. As a result opened files stay open for an unknown amount of time after simulation ends. A reload of the Flowchart is required to force closing the file (and even that fails at times). Being able to explicitly close a file when finished with it would help. (It would allow adding an event handler to Simulation.Stop to close the file).
A reliable work around would be very welcome... (can something be done with the functions in the System API???)
― C.S. Lewis
Re: Add Close to File API
Hi Jac,
Thanks we will take a look for you and I have added it to the list.
If you call the flush function then this should finish all pending transactions on the file. If you then set the file handle to 0 using a calculation icon then this may help to work around the issue.
