Adding a PS2 keyboard to your project
jose
Flowcode V4 User
Has thanked: 7 times
Been thanked: 10 times
Post by jose »
This program decodes data comming from keyboard and display its decimal value on a LCD.
It decodes normal keys and some extended keys like the arrows keys that maybe can be usefull to control something. The key value is store in "key_data" variable and you can use it for others purposes.
I think there is enough comments in flowchart showing how it works
Jose
PS2keyboard_jb.fcf
(13.25 KiB) Downloaded 1308 times
jose
Flowcode V4 User
Re: Adding a PS2 keyboard to your project
Post by jose »
After pressing a extended key, an arrow for example, you have to press the next key twice to have its value.
This new file correct this problem.
PS2keyboard_jb2.fcf
(13.79 KiB) Downloaded 1295 times
abed_hn
Has thanked: 3 times
Post by abed_hn »
jose wrote:After pressing a extended key, an arrow for example, you have to press the next key twice to have its value.
Thank you very much ... jose:)
it's work fine with 16f877a ...
but it's not working with 16f628a
when i put this MACRO (LCDdisplay)
if find this result
can you help me please ...
Genilsonsa
Has thanked: 12 times
Been thanked: 18 times
Post by Genilsonsa »
Good afternoon I come to thank the author of this topic, very useful projct this up until I added to my project I was doing. Thank you I ask
kersing
Has thanked: 553 times
Been thanked: 1081 times
Post by kersing »
Please use English in this forum.
― C.S. Lewis
Genilsonsa
Hello I need to make an interface to emulate a PS2 keyboard with pic 16F628A, but he would have to work with boot WINDOWS.Alguém can give me some light on how this will work.
Genilsonsa
It would be a project of emulating 14 letters of the keyboard .Pic send this to 14 letters pc.Tem how to implement this with Flowcode Can anyone help me on Protoco PS2.
As your making the keyboard itself is there any reason you are using PS/2 over USB? Our USB HID component will allow you to create a bootable keyboard using a USB enabled device.
I've had a quick look around but most projects seem to use a PS/2 keyboard to interface a PIC rather than using the PIC to create the keyboard.
Genilsonsa
Hello thank you for trying responder.Vou me implement this project via USB WITH PIC 18F2550 Thank .Very
Genilsonsa
Hello I have a doubt regarding the project with HID usb implementar.Tem like me who want to make a simulation in proteus or another program to see if it is working for windows 7 64bit
With USB it's better to dive in and get it working on hardware, simulation will be tricky at best and might not be possible in Proteus.
Here is an USB Keyboard example which should work great with hardware.
http://www.flowcode.co.uk/wiki/index.php ... 7a31b97c2a
One of our PIC ECIO devices might be good to help you get started as the USB communications comes working out the box and there is no nasty configuration setup etc.
