I'm very interrested in driving LCD and acquiring analogue signal. I tried your tutorial (Temperature probe projet) and followed all steps (included variables creation), but when I did Compile To ASM there were errors like :
ERROR 112 : TP8.ASM 114 : Missing operator
same errors lines : 171,183,204,217,311
ERROR 124 : TP8.ASM 204: Illegal argument (expected single character)
same errors lines: 204,217,311,345
I'm working with developpement board V3 and 16F88, and sames errors append when I'm targeting a 16F874 (only Compile To ASM).
Have you got any idea ?
Thanks in Advance.
Pascal
Errors using SensLib and tutorial Temperature Probe
Ian
- Been thanked: 1 time
Flowcourse uses C Code icons to access pre-written C libraries. Whilst these work with the original device they were created for, in the original compiler they were created for, when used with other devices or different compilers they can faile to compile, or not work as intended.
In short it is best not to use the SensLib functions.
(We are intending to totally redo that entire section as soon as we get the chance to do so).
A better and more flexible way to do this is to use the Thermometer component as an analogue input, and to use the LCD Display Component as well.
One advantage is that the ADC channel setup and the associated code is generated by Flowcode for the actual Device that is used, unlike the fixed SensLib code that can often be wrong for a particular chip.
Check the help file for the components for more details on how to use them, and also the Flowcode tutorial files. These were written with macros not C Code so demonstrate what we intended to be done.
Connect the Thermometer to the required ADC port.
Use an LCD Start macro to set up the LCD.
Use the SampleADC macro to sample the current analogue value.
This gets split into 2 values due to how the PIC works.
Use the ReadHigh and ReadLow macros to get the values.
Output the values to the LCD.
You can output one or both of the High or Low byte Analogue values, or do some calculations and display the full 10 bit number.
There is an Analogue/thermometer tutorial file (Tutorial 26) that you can look at. This displays the value in its full 10bit 0-1023 value so has the maths and display routines set out as well.
