Problem writing to sd card
Emanuel Lourenco
Been thanked: 8 times
Post by Emanuel Lourenco »
hi,
I'm here with a problem and do not know what could be.
I have a code to save 20 temperature probes for sd card.
But when I open the records from the recording appear esquecitos characters.
If any can help me grateful.
Thank you
1_3.txt
registration
(9.21 KiB) Downloaded 291 times
RTD_DataLogger_V1.15.fcfx
(139.51 KiB) Downloaded 302 times
Re: Problem writing to sd card
I think the problem may be down to your program structure.
A typical program will have a while 1 loop in the main which loops forever and calls the functions.
In your program the structure looks to be like this as one possible option.
Main -> Menu -> Registar -> FileName -> Menu -> Registar -> FileName -> Menu -> Registar -> FileName -> Menu -> Registar -> FileName -> Menu -> .......
As you can see we have re-entered the Menu macro and this will likely corrupt the first instance (if we ever get back to it). Best case scenario the stack will eventually fall over and then things get a bit unpredictable.
I would see if you can re-arrange your code so that it is called from a loop in the Main, maybe using variables to keep track of what your doing in the loop.
Emanuel Lourenco
Hi Benj
I made a program with only the part that is giving me problems, is much simpler.
But I still with the problem.
If I am able to help thanked
RTD_DataLogger_V1.15_main.fcfx
(72.36 KiB) Downloaded 293 times
oi.txt
(78.87 KiB) Downloaded 274 times
Emanuel Lourenco
hi,
I noticed that with several program to see my records, they never show the same mistakes.
Which program do you use to be records?
best regards
Emanuel Lourenco
After all is not the open log file program. I'm desperate. can help?
I've had a go at simplifying your program so you don't need as many variables etc. I'm not sure why you're getting the corruption but hopefully this should make it easier to see what's going on.
I have reduced the sensor count from 20 to 5 temporarily so we can quickly and easily change bits of the code without having to do it 20 times to see if it works.
I have reduced the append function down to a single cycle per loop and this should hopefully greatly reduce the comms to the card and hopefully also reduce the chance of the error.
RTD_DataLogger_V1.15_main-1.fcfx
(27.37 KiB) Downloaded 306 times
Have a go and let me know how you get on.
Emanuel Lourenco
hi benj
Thanks for the reply
I put your code to work and had the same problem.
I leave the file to view
best regards
oi.txt
(310.85 KiB) Downloaded 265 times
Is it the simulation or embedded code that is creating the log files with issues your posting? Looks like there is a bug lurking here somewhere.
Emanuel Lourenco
Hello benj,
The file I posted is what gave me when your post code on my hardware
Emanuel Lourenco
I'm back to my project.
But still no progress.
I leave the record of my memory card.
490 490 records in practically the value gets spoiled.
Does not detect a change lines.
What could it be?
File in Excel
greetings
(27.38 KiB) Downloaded 292 times
oi.xls
(205 KiB) Downloaded 262 times
hyperion007
Has thanked: 49 times
Been thanked: 101 times
Post by hyperion007 »
Can you please try this modified file and let us know if or how it worked.
/Daniel S
(29.99 KiB) Downloaded 315 times
Emanuel Lourenco
good Morning
It does not work. Gives the same error
Any more suggestions?
greetings
hyperion007
It still says that the file I provided hasn't been downloaded yet so how have you been able to test it?
edit: I just downloaded the file I provided and it instantly says it's been downloaded 1 time. I just wanted to make sure the information was accurate.
Emanuel Lourenco
hyperion007 wrote:It still says that the file I provided hasn't been downloaded yet so how have you been able to test it?
In his commentary is a file. I test this file. If you can post again thanked.
hyperion007
Sorry but I don't understand what you just said.
I have attached a file, which you have not downloaded...
hyperion007 wrote:Hi,
/Daniel S
Emanuel Lourenco
The file does not work. He just writes a record of each probe
Emanuel Lourenco
Good afternoon,
Any other opinion? I am desperate.
Does the configuration of DSPIC or perhaps viewing program records?
Attached leave the system I am using
Can I get help?
ujet32_plus_manual.pdf
(3.23 MiB) Downloaded 194 times
Looks like a nice little board, do the manufacturers know of any potential problems with the hardware?
Have you tried more than one card? Also have you tried formatting the card? I've received flash based devices before from sources like eBay and they are essentially fake but look the real deal until you try and store data.
Not sure what you mean by this.
Is there a pattern at all you can see to what is going wrong?
Have you tried reducing the number of sensors to 1 and seeing if you can get this to work reliably?
