Component creation freelancer wanted.
For anyone wishing to receive additional help with a project or simply looking to hire an embedded contractor we have a few contacts who would be more then willing to help.
headhuntergr
Has thanked: 34 times
Been thanked: 5 times
Post by headhuntergr »
Hello!
I am looking for someone to create me some components for flowcode V6, a display, a current sensor, a simple DAC, a ADC
I have datasheets if needed.
JohnCrow
Has thanked: 364 times
Been thanked: 716 times
Re: Component creation freelancer wanted.
Post by JohnCrow »
Have you seen this current sensor component?
http://www.flowcode.co.uk/mmforums/viewt ... 712#p51049
headhuntergr
Yes already i presume the acs711 (wich might get dumped for precision reasons) i want to use is something similar.
For now i am skipping the rest and focusing more on the display which is the most complicated part.
What is the controller IC on the display and do you have a pin out? Might be an easy one to push through.
headhuntergr
Hello Ben!
The controller is SP9210, here is a datasheet i found http://www.displayfuture.com/Display/da ... SP9210.pdf
Ok thanks I will look into this. Do you know if the displays your looking at have the 6080 or 8080 type interface. If you have a datasheet for the specific display then it should help me to get the pin properties and the code correct.
headhuntergr
I am looking to use it with SPI interface (the serial interface).
Doesn't seem to be anything else regarding this controller. There is only one datasheet.
The actual pixel size of the display is 128 x 36 dots
