eeprom check
siliconchip
Has thanked: 101 times
Been thanked: 25 times
eeprom check
Post by siliconchip »
hello,
I want to read the first 5 address's of eeprom then display the 3 highest values in order, I have got as far as reading the address's but im stumped as to how to put the 3 highest values in order and display, any pointers in the right direction would be appreciated i have added a flowchart of what ive got so far :oops:
eeprom check.fcf
(9 KiB) Downloaded 365 times
Re: eeprom check
I think you need to use something like a bubble sort algorithm. I believe Martin wrote one a while ago you should be able to use.
http://www.flowcode.co.uk/mmforums/viewt ... 73&#p22074
More discussions on it here.
http://www.flowcode.co.uk/mmforums/viewt ... 14&p=56230
siliconchip
Re: eeprom check
hi benj thanks for the reply the links you added involved me on an earlier project and I have already tried to add some of this flowcode to my problem but im going round in circles and cant quite get my head around the bubble sort I will keep trying
Re: eeprom check
Hi Bob,
Attached flwochart should make things eaiser for you. :)
eeprom check v2.fcf
(15.14 KiB) Downloaded 386 times
siliconchip
Re: eeprom check
hi martin
as always many thanks I was taken aback a bit as there isn't any of my original code which from a learning process is a blow BUT hats off to you I now have some thing to work on and hopefully by going through it can get a better understanding thanks :D
Re: eeprom check
Your welcome.
siliconchip wrote: I was taken aback a bit as there isn't any of my original code which from a learning process is a blow
There are different ways to achieve the same results.
Just because you was trying a different way to me and I changed it, does not necessary mean that your method was wrong.
