This bug prevents use of some items on Flowcode and affects the code generated.
Chip used : Atmega168 and 328P
Ports on led array (8) Custom PINS: C5 C4 C3 C2 C1 C0 B1 B2
Ports on switch array (8) Custom PINS: B0 d7 D6 D5 D4 D3 D2 D0
Program structure (to reproduce):
Start
Forever loop
_|
Call component macro
sw_status=switch_array::ReadAll()
_|
Led_Array::WriteValue(sw_status)
_|
LOOP FOREVER-
End
Try to compile to chip/hex.
LOG:
Flowcode.msg.txt wrote: Tuodaan kääntäjää...
C:\Program Files (x86)\Flowcode 6\compilers\avr\batchfiles\avra.bat atmega168 "C:\Users\Jari\DOCUME~1\FLOWCODE\PLC-01\Hitachiohjelma.elf" "C:\Users\Jari\DOCUME~1\FLOWCODE\PLC-01\Hitachiohjelma.c" "C:\Users\Jari\DOCUME~1\FLOWCODE\PLC-01\Hitachiohjelma.lst"
Launching compiler...
C:\Users\Jari\DOCUME~1\FLOWCODE\PLC-01>"C:\PROGRA~2\FLOWCO~1\COMPIL~1\avr\BATCHF~1\..\bin\avr-gcc.exe" -mmcu=atmega168 -Os -funsigned-char -o "C:\Users\Jari\DOCUME~1\FLOWCODE\PLC-01\Hitachiohjelma.elf" "C:\Users\Jari\DOCUME~1\FLOWCODE\PLC-01\Hitachiohjelma.c" -lm
C:\Users\Jari\DOCUME~1\FLOWCODE\PLC-01\Hitachiohjelma.c: In function 'FCD_03d9a_led_base1__TurnOn':
C:\Users\Jari\DOCUME~1\FLOWCODE\PLC-01\Hitachiohjelma.c:592: error: 'FCP_TRIS_A' undeclared (first use in this function)
C:\Users\Jari\DOCUME~1\FLOWCODE\PLC-01\Hitachiohjelma.c:592: error: (Each undeclared identifier is reported only once
C:\Users\Jari\DOCUME~1\FLOWCODE\PLC-01\Hitachiohjelma.c:592: error: for each function it appears in.)
C:\Users\Jari\DOCUME~1\FLOWCODE\PLC-01\Hitachiohjelma.c:592: error: 'FCP_PORT_A' undeclared (first use in this function)
C:\Users\Jari\DOCUME~1\FLOWCODE\PLC-01\Hitachiohjelma.c: In function 'FCD_03d9a_led_base1__TurnOff':
C:\Users\Jari\DOCUME~1\FLOWCODE\PLC-01\Hitachiohjelma.c:602: error: 'FCP_TRIS_A' undeclared (first use in this function)
C:\Users\Jari\DOCUME~1\FLOWCODE\PLC-01\Hitachiohjelma.c:602: error: 'FCP_PORT_A' undeclared (first use in this function)
C:\Users\Jari\DOCUME~1\FLOWCODE\PLC-01\Hitachiohjelma.c: In function 'FCD_05261_switch_base1__ReadState':
C:\Users\Jari\DOCUME~1\FLOWCODE\PLC-01\Hitachiohjelma.cerror: 'FCP_PIN_A' undeclared (first use in this function)
C:\Users\Jari\DOCUME~1\FLOWCODE\PLC-01\Hitachiohjelma.cerror: 'FCP_TRIS_A' undeclared (first use in this function)
C:\Users\Jari\DOCUME~1\FLOWCODE\PLC-01\Hitachiohjelma.c: In function 'FCD_05261_switch_base1__WaitUntilHigh':
C:\Users\Jari\DOCUME~1\FLOWCODE\PLC-01\Hitachiohjelma.c: In function 'FCD_05261_switch_base1__WaitUntilLow':
Error returned from [avr-gcc.exe]
Completed compilation, return = 1
C:\Program Files (x86)\Flowcode 6\compilers\avr\batchfiles\avra.bat reported error code 1
