It would be so nice if I could have the ability to set the color of icons to indicate things like a piece of diagnostic code. So in a macro I want to do a calculation and print to RS232/LCD whatever. Basically used in troubleshooting. I would like to have them all turn Red or whatever color is designated as the Diagnostic/Debug color.
On top of highlighting them so I can quickly tell what is worth looking at or not I'd like to be able to instruct Flowcode that all Diagnostic/Debug marked Icons are to be disabled or enabled. This would make removing the diagnostic code easy and then recompile so you can test without all of the diagnostic output.
Maybe even multiple levels of diagnostic highlighting and disable/enable.
Thanks!
Trevor
2 items...
Forum rules
Only feature requests will be considered here. General questions should not be posted in this forum.
Re: 2 items...
Hi Trevor,
Thanks for the suggestion some very good ideas there. I'll get them on the list.
