Code Offset bug ?
A forums to allow bugs and problems with Flowcode v6 to be reported and resolved.
faveremario
Has thanked: 8 times
Been thanked: 13 times
Code Offset bug ?
Post by faveremario »
Hi all,
I wrot a small FC6 program (for PIC18f2455) using the linker directive : -rb 0x1000 (for using with the µchip HID bootloader)
When I look at the code, I see that it starts @ 0x800 in stead of 0x1000 !
In attachement the HEX-file.
ANy suggestions are welcome...
I'm using FC6.1.1.0
greetz
USBSerial.hex
Linked with the -rb 0x1000 directive.
(11.64 KiB) Downloaded 265 times
kersing
Has thanked: 553 times
Been thanked: 1081 times
Re: Code Offset bug ?
Post by kersing »
It would be better if you posted your flowchart and export of the compiler and linker settings for us to look at.
― C.S. Lewis
LeighM
Has thanked: 481 times
Been thanked: 699 times
Post by LeighM »
The hex file attached looks like it does start at 0x1000, to me
Yes I agree with Leigh, All memory locations before address 0x1000 are NOPs.
I used MPLAB to get this program memory listing from your hex file.
faveremario
Hi all
Now today I found 'a solution' and why i tought the code-offset was wrong.
I opened the hex with notepad & saw the code started at 0x1000, so my first impression was wrong.
I was mislead by the way the HID-bootloader functions : when in bootloader is initiated (a button must be pressed while initiating) & connected to the PC, 2 led’s are alternatedly blinking.
After the programming, we reset the PIC without pressing the ‘bootloader’-button so the user-program is starting to run.
But this did not happen…. The bootloader sequence was entered. This is generaly a sign that the user-program has not been transferred into the PIC (very often related to code-offset mismatch).
The FC6 did simply set-up a USB serial communication with the PC, sending a counter-value every 1sec.
Solution : I must deconnect the USB-cable, then reset the PIC. The user-program is now starting to run (bootloader is skipped) then reconnect the USB-cable.
I have not the smallest idea why the usb-cable may not stay connected when resetting the PIC….
