PROBLEM TO OPEN FILES
electron67
Has thanked: 106 times
Been thanked: 48 times
Post by electron67 »
HELLO,
I HAVE PROBLEM WHEN OPEN FILE :
Access to C:/DOCUME-1/ARTURO/CONFIG-1/Temp/MXT27.tmp was denied.
What is wrong ?
THANKS
ENRIQUE
Re: PROBLEM TO OPEN FILES
Hi Enrique
Not sure why you want to open MXT27.tmp?
What has that got to do with Flowcode V5?
Sounds like something else is accessing the temp file your trying to open.
electron67
I not understand, what I'm trying to open an FLOW chart AND WHEN I WILL OPEN APPEARS WINDOW AND DENIED ACCESS; FILES ARE .fcf;
I also denied access to open the file with flowcode 6, the name of file is KEY3.1.fcf or any other flowchart; I never had this happen
Access to C:/DOCUME-1/ARTURO/CONFIG-1/Temp/MXT27.tmp was denied. or
Access to C:/DOCUME-1/ARTURO/CONFIG-1/Temp/MXT28.tmp was denied. or
Access to C:/DOCUME-1/ARTURO/CONFIG-1/Temp/MXT29.tmp was denied. or
Access to C:/DOCUME-1/ARTURO/CONFIG-1/Temp/MXT30.tmp was denied. or
C:/ Documents and Setting/Arturo/Escritorio KEY3.1.fcf was denied
Enrique
Sorry for my english
This is not something I know much about.
Have you tried moving flowchart to a newly created directory on the root of your main drive?
Also could a firewall or antivirus program be stopping you gaining access?
electron67
HI, Martin
I recorded my flowchart into a usb memory, my documents and desktop pc, I will create a new directory for the flowcharts to see if the problem is resolved. My fear is that I saved the work of several years in those folders and I do not like to lose all the projects I've done and start over
THANKS
