Crop Function for System & Dashboard Panels
Please add any feature requests for Flowcode version 6 here
Forum rules
Only feature requests will be considered here. General questions should not be posted in this forum.
Currently if I want to reduce the size of the System or Dashboard panels, then having to drag the corners which not only proportionally reduce size of the components, but components also disappear out of view.
The you will have to resize components which is awkward if reduced too much
A crop function would be very useful, or let panels on v6 work in a similar fashioned to V5.
I.e drag to reduce size and leave components same size as they were.
LeighM
Has thanked: 481 times
Been thanked: 699 times
Re: Crop Function for System & Dashboard Panels
Post by LeighM »
Hi Martin
Interesting thought, but did you know that you can hold down the Ctrl key and then use mouse scroll wheel to zoom in and out?
Rgds
Leigh
Hi Leigh
LeighM wrote:ut did you know that you can hold down the Ctrl key and then use mouse scroll wheel to zoom in and out?
Yes I did,but thanks.
You can do the similar thing with zooming in/out, but the components keep moving and resizing so you have to group and move several times to get it right.
Then if you want to add a another component , you will need to zoom out , then all components realize so are smaller than intended.
Takes a fair bit of time .
Whereas crop or drag corner and components not recognizing is instant.
Perhaps the simplest method would be a check box to stop components auto resizing?
