Flowcode 6.1 Released!
Rudi
Has thanked: 493 times
Been thanked: 187 times
Re: Flowcode 6.1 Released!
Post by Rudi »
Hi Guys
i
-download it,
-install it (XPSp3),
-run it ( without need again register ) ,
and i am happy first time.
very tidy.
very stable
very welcoming to the next new microcontroller experiment
Great Work MM Staff !!!
but ;-) now i will test all asap and next times ;-) and will let you know how the second time is ;-)
Best wishes
rudi ;-)
ps
one I've missed,
"USB MIDI"
http://www.flowcode.co.uk/mmforums/viewt ... 56&t=14981
..but that's on the list and I think it will come soon
trevorpierce
Been thanked: 2 times
Post by trevorpierce »
Thanks for the update...
A little over two weeks ago I noticed that the software I was working on was restarting multiple times a day. Never noticed it before. Just recently I wrote it so that on startup it posted to the RS232 port the app name etc. I had also just plugged in a bluetooth module. Not sure what to do I started pulling parts. Still rebooting.
I ended up writing a program to just post to the RS232 upon startup and blink some led's to know that it was running. It would reset multiple times a day. I wrote a similar app in Mikroe C (this is all being run on a EasyPIC PRO 7) the Mikroe C code ran and ran no resets. Couldn't get Flowcode to keep from resetting.
Upgraded to 6.1 and recompiled the basic test app to see if it would reset. Ran and 24hrs later no reboots. So I recompiled the main app and it's been running for 9hrs and no resets. Very happy that it's stable but wondering why??
Any idea what was going on with the older version. I was running v6.0.4.0.
Thanks again for the update...
Trevor
Hi Trevor,
Could have been stack corruption or something similar. Would probably need to see the compiler messages output to see if there are any potential problems lurking.
trevorpierce
Okay, well if the problem shows up again I'll look into this further. For now I'm going to hope it never happens again and move forward.
Trevor
Bill Felker
Flowcode v5 User
Has thanked: 18 times
Been thanked: 12 times
Post by Bill Felker »
Does flowcode support the Trinket AVR/Arduino ?
Bill
ardiles
Has thanked: 7 times
Been thanked: 1 time
Post by ardiles »
hi all!
i try to install flowcode v6 6.1.0, and I encountered the problem of translation...i can change the language, and default translate is RO and the translate is broken!
Not currently but it looks like it should be possible. I'll add it to the list.
Do you have one available as I would need some information about it. If you look at the device in device manager then I need the following info.
USB PID & VID and Device Name
Here is an example for the Uno R3
pid="0043"
vid="2341"
devdesc="Arduino UNO R3"
Please could you send us a screen shot of the issue so we can see what you mean.
ardiles
Post by ardiles »
print screen:
start screen
(194.13 KiB) Downloaded 7604 times
(97.67 KiB) Downloaded 7604 times
Hello Ardiles,
Many thanks for reporting the bug. We have found the problem and are currently in talks with the translators to get this resolved.
ardiles
Post by ardiles »
i am happy to hear this!
PS: why can i change the default language? i want choose english.
MartinB
Has thanked: 3 times
Post by MartinB »
ardiles wrote:i am happy to hear this!
Hi Ardiles
You can deselect the language override by changing the relevant registry entry (HKCU\Software\MatrixMM\FlowCodeV6\Options\OverrideLang = 0) which should return you to English.
If you double click on the attached file "back_to_ENGB.reg" this should do the work for you (need to be admin) hopefully
back_to_ENGB.zip
double click this as admin user
(300 Bytes) Downloaded 506 times
Support for the Adafruit Trinket device has now been added - http://www.flowcode.co.uk/mmforums/viewt ... 54&t=15492
Rudi
Post by Rudi »
Hi guys
still availabel in 6.1 too.
http://www.flowcode.co.uk/mmforums/viewt ... 885#p60154
FC 6.0.7.0 ( 28.03.2014 )
Theme: Template
Scrolling Project Description
After Click to the Template and want scroll the Project Description, the project Description is not scroll, the Icon;s of Temlate is scrolling .. and hidden...
Again click to other Template the Field will be white... and must restart the process "open a Template" for can selecting ..
and CAL_ADC Sample Mode
http://www.flowcode.co.uk/mmforums/viewt ... 885#p60221
i hope you guys will sort this in next fc 6 release :)
Rudi
ps
benj come back.....benj come back...:)
PINTO
Flowcode v5 User
Post by PINTO »
Hi David,
Hi upgraded my v6.0.9 pro to v6.1.1.0 (22.01.2015) and now flow code changed from pro version to home version and I lost the licence to most of the components.
What do I have to do?
Pinto
JohnCrow
Has thanked: 364 times
Been thanked: 716 times
Post by JohnCrow »
I had this problem on Sunday evening. David told me on Monday there had been a problem with the registration database. I tried again on Monday evening and it registered as pro version.
PINTO
Flowcode v5 User
Post by PINTO »
Hi John,
Thaks for the info but mine still says "Home Version" and a lot of the components are not licensed.
I really appreciate the fact that you took the time to try to answer me but I'm still stuck. Unfortunatly I can't say the same of thre matrixmultimedia team. :roll: Maybe they to busy with more importante maters.
Thaks John
Pinto
DavidA
Has thanked: 58 times
Been thanked: 258 times
Post by DavidA »
Please can you PM me your username and i will check the database for you.
STibor
Has thanked: 116 times
Been thanked: 113 times
Post by STibor »
Hello!
The automatic update 6.1.0. was updated.
Current version 6.1.1.
kersing
Has thanked: 553 times
Been thanked: 1081 times
Post by kersing »
STibor wrote:Hello!
You probably missed this message: Flowcode 6.1.1.0 released
― C.S. Lewis
Stanga
Post by Stanga »
I just updated 6.1 to 6.1.2 and I am experiencing a very odd problem. One of my files compiled on 6.1 and left me with 8 locations free in a PIC16F628A. The recompiled version using 6.1.2 comes up with a failure notice and leaves me with 530 locations short!
Just to make sure I was not imagining things I restored my PC from a back up and double checked.
I am doing some more tests, but can anyone try compiling a program of theirs in 6.1 and then check it in 6.1.2?
Hello Stanga,
Could you attach or PM me your file and I will look into this for you.
Stanga
Post by Stanga »
Hi Benj, OK, shall do right away.
