Ping Sensor
A forum where Flowcode v6 user created components can be shared, discussed and reviewed.
willow
Ping Sensor
Post by willow »
hi can anyone help with the configeration of the a hc-sr04 ultrasonic sensor as the example code I've adpted will only give me 17 or 0 output through a serial port.
Please see Below :
Comment:
This example program is configured to measure approximately 1.5-2m (150 - 200cm) from the sensor.
If much shorter distances are used, parameters will need to be changed.
Call Component Macro:
Loop:
1
<LOOP>
Allows the potentiometer to be used to set the threshold level:
sense = sense / 20
Delay:
100 ms
Calculation:
dist = ToString$ (distance)
sens = ToString$ (sense)
</LOOP>
Re: Ping Sensor
Hi willow,
Perhaps a starting point would be this whole thread
If you do try the flowchart and get stuck then let us know.
willow
Re: Ping Sensor
Post by willow »
The sensor is working ok with the arduino ping sketch example ,but it seem's more difficult to make it work on the flowcode 6 software ,the distance I'm working with is about 30-150mm max.
