Flowcode6 1602 LCD problem
ahmetnoktacom
Hello my friens,
I have problem about LCD writing. I have arduino uno and LCD Keypad Shield. when I write program arduino original program Writing is succesfull. but I try to write with Flowcode 6, I could not writing anything.
when simulation mode in flowcode, I see program is working and LCD panel writing. but in real not work LCD panel.
I think my problem, panel port number in flowcode. normaly arduino pin numbers (8,9,4,5,6,7)
you can see my program in attachment.
- LCD_EV.fcfx
- (4.15 KiB) Downloaded 613 times
Re: Flowcode6 1602 LCD problem
Please can you try this program. I have simply moved the code to write to the LCD out of the loop so that the micro is not simply re-writing to the display constantly.
Everything else looks to be correct.
ahmetnoktacom
hello,
Thank you for your help. I tried but same problem it is not work. in simulation mode it is working, but in real not work.
ahmetnoktacom
hello, LCD work arduino program in attached. but it could not be worked flowcode 6. yesterday I downloaded flowcode 5, ı think maybe flowcode 6 problem but it was not working. ı dont understand. ı think my problem can be pin description. ı looked, everything like normal.
I am waiting your help
- lcdtest2.rar
- (979 Bytes) Downloaded 560 times
ahmetnoktacom
HELLO,
My flowcode licence is student version. is lcd working possible ? My program work in Proteus isis, and flowcode 6 simulation. but in real it is not work. ı will be crazy, ı dont understand.
help me please... urgently
Can you post a diagram or state what LCD pin numbers go to what arduino digital number, then I can see if they match upahmetnoktacom wrote: I think my problem, panel port number in flowcode. normaly arduino pin numbers (8,9,4,5,6,7)
ahmetnoktacom
hello
LCD pin number arduino uno pin numbers
D4 D4
D5 D5
D6 D6
D7 D7
D8 D8
D9 D9
D10 D10
VSS GND
VDD 5V
I tried this even with arduino nano but result same, LCD not work. I changed arduino pins in program and hardware but result same. LCD not work with flowcode.
ı could not solve.
D4 D4
D5 D5
D6 D6
D7 D7
D8 D8
D9 D9
D10 D10
VSS GND
VDD 5V
ı could not solve.
ahmetnoktacom
I tested in proteus isis, it is working. I inserted picture in attached. but ı coult not work in real. I made every thing same but not work...
- ard_isis.jpg (215.02 KiB) Viewed 17884 times
It could be there is a subtle difference required in the configuration of your LCD to get it to fire up.
If you use the search item in the components toolbar and search for LCD then you will find there are a number of different components you can try.
I would recommend trying these to see if any of these work to drive your display.
LCD (Adafruit, OLED)
LCD (EA W162-XBLW)
LCD (Generic)
Let us know how you get on.
LCD (EA W162-XBLW)
LCD (Generic)
ahmetnoktacom
HELLO,
I tried your said, I used LCD Generic, but not changed anything.
ahmetnoktacom
what can be problem? LCD panel work, because in arduino original program, I load program to arduino LCD work. but I could not work with Flowcode 6 and 5. I tried every thing. I could not solve.
It sounds like the display on the shield is not a standard LCD. We have used the same component code for years and it has always reliably worked on a wide range of devices. The difference is however probably quite small. Can you send me the Arduino code so I can compare it to the Flowcode LCD component code. I can then probably do a small change and give you a new component that should work.
The file you previously attached "lcdtest2.rar" only contains the .ino source file which refers to an external LCD library. It's the LCD library your using that I would need.
ahmetnoktacom
HELLO,
This is liquid crystal library,
- LiquidCrystal.rar
- (13.75 KiB) Downloaded 510 times
Thanks,
I have compared the startup codes and they are very similar.
The Adafruit OLED type LCD components have a slightly different init routine, have you tried these components? They only appear in the search component category.
ahmetnoktacom
hello,
I found LCD Adafruit OLED. it look like my LCD. but in properties, rw_pin is problem. because rw_pin connect directly to ground (-). in flowcode, I have to select any pin for rw_pin. I could not select ground or minus. so not change any thing.
Thank you your help.
For the RW pin property do you have an unused pin you could assign just to test if the component will work to drive your display.
ahmetnoktacom
I connected RW to D0. in properties and hardware I set RW to D0. in program I set D0 =0 and D0=1 but not work.
ahmetnoktacom
ok ok I understand I can not make this panel.
which panel must I use with flowcode?
ahmetnoktacom
ahmetnoktacom
hello,
I repaired LCD now working with arduino ide program.
for flowcode, I am waiting your help
Nasim Khaliqhey
- Has thanked: 1 time
- Been thanked: 3 times
Re: Flowcode6 1602 LCD or EBM001 problem
Dear Informers
Idon´t know where in my programming part is not right
I spend lots of time with PIC16F1872 ,LCD 1602 and EBM001 .
What I can see the results are
LED works ok regarding to An0 &An1(RA0 &RA1) 1 & 0 conditions
what I don`t understand why not running the Data in Display
can any one send me the right configuration bits list for the mention problem.
if I remember the condition of interring picture data to a cathode ray tube TV,Data was up side down
there for I thing the graph of B0 data output shows me right shape ,
& the clock pules is also OK to .
If I keep my eyes on EBM001 for few minutes I can see a slight shadow of data movements hope it is not my
sight or ......gusts .
looking forwared hearing from you.
wr
Nasim
wr
Nasim
- (547.28 KiB) Downloaded 3060 times
Nasim Khaliqhey
Re: Flowcode6 1602 LCD & gLCD problem
regarding to last report and received advice
I redesigned new power supply with 1A 5 outputs
1- 4v98 for PIC16F1827 drive (4v98 is the output from an 7805 constant ouput regulator)
2- 3v3 for gLCD EBM_001 DRIVE (3V3 is the output from an LM317 Adjust regulater)
the result is the same has it was mention be for
wr
Nasim
wr
Nasim
