Arduino Uno + LCD Keypadshield FC6
jgu1
Has thanked: 1135 times
Been thanked: 299 times
Post by jgu1 »
Hi all!
Since upgrading to FC6. PIC + AVR I have in my eagerness to test the functionality dabbled a little with Arduino.
I made a small test program to Arduino uno + lcd keypad shield in FC 6.
Arduino Uno: http://arduino.cc/en/Main/arduinoBoardUno
The LCD keypad shield: http://www.miniinthebox.com/da/16-x-2-l ... 40888.html (randomly chosen page)
The LCD keypad shield Sheet: http://www.dfrobot.com/image/data/DFR00 ... 9SCH01.pdf
First, you need config compiler options, according to Ben's instructions: http://www.flowcode.co.uk/mmforums/viewt ... 54&t=13084
There is a similar program to C + + for Arduino somewhere.
As you can see in the diagram consists keypad function of an analog input. The values determined by the resistor network. This way you get different values depending on which button you press. One input is many input on this way.
Maybe usefull :lol:
Best regard
Jorgen
ArduinoShieldTest.fcfx
(13.77 KiB) Downloaded 854 times
ahmetnoktacom
Re: Arduino Uno + LCD Keypadshield FC6
Post by ahmetnoktacom »
Hello, could you write anything to LCD shield? I cannot write
jgu1
Post by jgu1 »
Hi ahmetnoktacom!
Yes I can, it Work perfect, otherwice I have not anounced here :D
Best regard
Jorgen
ahmetnoktacom
Why I could not write. what can be my wrong.
viewtopic.php?f=54&t=16706
above is my old topic, ı tried everything but unsuccessful
jgu1
Post by jgu1 »
Hi.
Are you using an Arduino Uno and arduino display/keypad (buttom) Shield ?
Maybe your Arduino or display are deffective. I guess. Have you tryed to add a 1 sec output flasher in your programm so you Can see that the controller is running.
Mine is working perfect.
Br
Jorgen
ahmetnoktacom
arduino is running and even with arduino ide program, lcd keypad shield is working. in flowcode, arduino is work, but in flowcode ı could not do anything about lcd, not work lcd. ı can do control back light but write problem.
