Pic 12F683 with external RC or Internal Clock
calimero88
Post by calimero88 »
Good morning.
I tested a PIC 12F683 with external Clock : the project is not work with internal Clock ( 8 MHz ) or external RC Clock . I use EB006 V7 and EB 004.
Test 18F252.fcfx
Test 12F683 with internal clock no clockOut
(4.84 KiB) Downloaded 292 times
QMESAR
Has thanked: 384 times
Been thanked: 614 times
Re: Pic 12F683 with external RC or Internal Clock
Post by QMESAR »
The file you attached is for a PIC18F252 and you mentioned PIC12F in your post so what are you now working with and with which chip do you have a problem
calimero88
good morning .
i have a error file attachement.
Sorry.
test_12f683.fcfx
(4.76 KiB) Downloaded 282 times
QMESAR
Post by QMESAR »
In my opinion there are a few things you are not doing and that is the reason your internal oscillator is not working
(1) you have to use a C function call and set the OSCCON register to your needs
(2) if you are not clearing the watch dog in your FC diagram then you should not enable the watch dog timer
(3) why do you enable the Oscillator switch over mode as you are using the Internal OSC
Check the datasheet page 19 how to use the Internal Oscillator
calimero88
My config is correct.
(310.45 KiB) Downloaded 787 times
QMESAR
Post by QMESAR »
You clearly did not read my post properly :D
however if you believe your config is correct so be it , also if you do not want to set the OSCCON register so be it too :D
cannot make you do this hope you get it running
calimero88
I tested other config 12F683. it is work .
See image attachment.
(291.97 KiB) Downloaded 783 times
