Hi, I was looking through my program listing to un-install a file, and I noticed there are two flowcode version 6 installed.
One is 6.1.0.0 taking up 964Mb
and the second 6.1.2.0 963Mb (wow, my first hard drive was 5Mb)
Will it be safe to delete the earlier one, and is there a chance it will impact on the one that's left.
Sorry for what probably seems a dumb question, but I've never come across multiple instances like this.
thanks john
two flowcode v6 installed?
john_m0ers
- Been thanked: 3 times
Re: two flowcode v6 installed?
Hi John,
I don't believe there will be any impact on the one that's left.
But just in case you can run the repair feature by going to your PC Control panel, Add remove features then select the flowcode that's installed.
The word Repair will appear.
I don't think it would be necessary.
john_m0ers
Hello Martin,
Thanks for replying. Some other times my program manager has a hiccup and shows multiple installations.
If one was deleted, they all vanished! That turned out to be a corrupted registry section. I did un-install the
earlier version successfully, so thank you for your advice.
