Mifare RC522 RFID
Forum rules
Only feature requests will be considered here. General questions should not be posted in this forum.
- STibor
- Has thanked: 116 times
- Been thanked: 113 times
Mifare RC522 RFID
Hi!
Do I have a very urgent RC522 component of the macro.
http://www.ebay.com/sch/sis.html?_nkw=M ... 7675.m4099
If this is not possible, which is compatible with the RFID reader RFID components v6 Flowcode macros?
It would be very important!
Re: Mifare RC522 RFID
The Flowcode RFID component is compatible with these modules.
http://www.rfsolutions.co.uk/acatalog/i ... ICODE.html
Saying this I have done some work with the RC522 module so I'll have trawl through and see if I can find it.
- STibor
Benj Thank you!
Unfortunately, these modules are not available to me.
As you can tell processed by a micro controller chip serial data and builds up in the RFID chip transceiver protocol.
Benj Thank you!
It took me a while but I eventually managed to find it. Could probably be wrapped up into a component without too much effort.
jgu1
- Has thanked: 1135 times
- Been thanked: 299 times
Hi Stibor!
Very interesting. Please let us hear your test result.
Bet regard
Jorgen
Bet regard
Jorgen
jgu1
Hi Stibor!
Very interesting. Please let' s hear hear your test and result.
Best regard
Jorgen
Best regard
Jorgen
- STibor
Hello!
The card recognition okay.
The ID readout is not working.
What is bad?
What is bad?
- RFID_MFRC522.fcpx
- (5.12 KiB) Downloaded 963 times
- Flowcode1.fcfx
- (9.77 KiB) Downloaded 961 times
- (79.9 KiB) Downloaded 17272 times
jgu1
Hi.again!
The reconition and the ID is that not the same? And what is the nummer i your display? Is it those Wich not is correct?
BR
Jorgen
BR
Jorgen
Yes I can create a component if all is well, if there are problems then lets try and get them fixed first.
Can you tell me what you think is wrong with the IR readout?
- STibor
Hello!
The problem was that for the first time generated component, and the component was tested.
I tried the MFRC522.fcf your program, this data has come.
The problem is that the data is the same as two RFID card.
Every time you turn on changes to the data read from the seventh.
This picture shows a value of 15. But was 48, 0, 78.
- (46.1 KiB) Downloaded 17078 times
So the data read back from the module changes every time you power up the module is that right?
Also the data read back from different RFID tags are the same?
Have you compared my code to any existing code? I created this code a few years ago and can't remember the status it was left in though I'm pretty sure it should work.
I'll go back through my emails to see if I can find more info.
- STibor
1. Power Card Recognition (yes / no) okay.
2. Data readout: changing the read data and then stops at a value.
3. The same data read all card.
I tried an Arduino library.
The same hardware (mega2560), the same electrical connections.
Arduino works by example.
Arduino lib:
https://github.com/miguelbalboa/rfid
Arduino lib:
jgu1
Hi Ben and Stibor!
I found this project very interesting and usefull. (I have a look here every day)
Should it be possible to write new ID to the Card/tag also, or this is maybe not posiible to change .?
So (kindly) ask, does the tread stop here as I understand on Stibor there are still bugs?
BR
Jorgen.
BR
Jorgen.
- STibor
Hello!
I tested Arduino Mega 2560, it was not good.
Unfortunately, I do not know what can be a problem.
Each RFID card given the same ID.
I read the UID would be enough.
I'll see if I can find some time this week to go back over the code and check it for bugs. We are pretty busy at the minute so may not get onto it this week but I will try. If it falls off my radar then feel free to pester me, I'm juggling a lot of things this week and my brain can only store so much
jgu1
Hi Ben!
Ok Ben thanks for answers. We can well imagine you are in a hurry. we must have patience.
But we chasing you if going for a long time
BR
Jorgen
BR
Jorgen
jgu1
Hi Ben!
I dare to ask
Have you found some time for this issue please.
I am very curious and find the project very interesting, and I will Invest in some of these module if they can work with Flowcode.
Best regard
Jorgen..
I dare to ask
Best regard
Jorgen..
jgu1
Hello Jorgen,
I'll have a look but that Arduino library is looking even more unreadable then I last remember it. The code has changed significantly so it looks like we have to do a lot to catch up again.
I'll see how I get on and let you know.
jgu1
Right I have spent a few hours on this now and it seems the further down the rabbit hole I go the more lost I get. The library is obviously written in a slightly obfuscated way and seems pretty horrible to follow through.
Anyway this is going to take some time to do properly.
Keep pestering me and I will keep trying to move this forward.
