Measurement of temperature and relative humidity using DHT11
Re: Measurement of temperature and relative humidity using D
I tried DHT11v1.01.fcf with ECIO-40P. But it gives CheckSum Error, Trying again... Can you help me please.
Hi paridhi,
The errors are caused because ECIO-40 has a 16bit timer0 but the V5 flowchart was designed for 16F877A which has a 8bit timer.
Therefore all the C code blocks referring to tmr0 will produce an error.
You could use timer2 instead of timer0 and change all to .
Also when changing timer interrupt component to timer 2, it would be best if you can change to the following values:
Then if all goes correctly should compile:
tmr0 Code: Select all
tmr2Also when changing timer interrupt component to timer 2, it would be best if you can change to the following values:
Prescaler = 1:4
Postscaler = 1:3
Rollover = 205.Code: Select all
File name: C:\Users\Martin\Downloads\DHT11v1.01.c
Title:
Description:
Generated by: Flowcode v5.5.2.1
Date: Wednesday, April 06, 2016 22:22:06
Licence: Professional
Registered to: Martin ********
Licence key: 6HEP0Q
Launching the compiler...
C:\Program Files (x86)\Flowcode\v5\Tools\boostc\boostc_pic18_flowcode.exe -v -t PIC18F4455 "DHT11v1.01.c"
BoostC Optimizing C Compiler Version 7.04 (for PIC18 architecture)
http://www.sourceboost.com
Licensed to FlowCode User under Single user Pro License for 1 node(s)
Limitations: PIC18 max code size:Unlimited, max RAM banks:Unlimited
DHT11v1.01.c
Starting preprocessor: C:\PROGRA~2\Flowcode\v5\Tools\boostc\pp.exe DHT11v1.01.c -i C:\PROGRA~2\Flowcode\v5\Tools\boostc\include -d _PIC18F4455 -la -c2 -o DHT11v1.01.pp -v -d _BOOSTC -d _PIC18 -d _CHAR_INDEX
DHT11v1.01.c success
success
Return code = 0
C:\Program Files (x86)\Flowcode\v5\Tools\boostc\boostlink_pic.exe -rb 0x800 -ld "C:\Program Files (x86)\Flowcode\v5\Tools\BoostC\lib" libc.pic18.lib rand.pic18.lib float.pic18.lib "DHT11v1.01.obj" -t PIC18F4455 -d "C:\Users\Martin\Downloads" -p "DHT11v1.01"
BoostLink Optimizing Linker Version 7.03
Warning unreferenced functions removed:
FC_CAL_Port_In__x in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_IO.c
FC_CAL_Port_In_DDR__x in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_IO.c
FC_CAL_Port_Out__x in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_IO.c
FC_CAL_Port_Out_DDR__x in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_IO.c
Wdt_Delay_S in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_Delay.c
FCI_DELAYINT_US in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_Delay.c
FCI_DELAYINT_MS in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_Delay.c
FCI_DELAYINTWDT_MS in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_Delay.c
FCI_DELAYINT_S in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_Delay.c
FCI_DELAYINTWDT_S in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_Delay.c
FCI_GETCHAR in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_String.c
FCI_GETLENGTH in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_String.c
FCI_MIDSTRING in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_String.c
FCI_LEFTSTRING in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_String.c
FCI_RIGHTSTRING in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_String.c
FCI_TOSTRING in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_String.c
FCI_TOLOWER in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_String.c
FCI_TOUPPER in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_String.c
FCI_COMPARE in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_String.c
FCI_FLOAT_TO_STRING in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_String.c
FCI_NUMBER_TO_HEX in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_String.c
FCI_STRING_TO_INT in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_String.c
FCI_STRING_TO_FLOAT in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_String.c
FCI_STRREV in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_String.c
FCI_STRMOV in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_String.c
FCI_SHEAD in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_String.c
FCI_SCOPY in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_String.c
isinf in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_Float.c
flt_round in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_Float.c
flt_floor in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_Float.c
flt_ceil in: C:\Program Files (x86)\Flowcode\v5\CAL\PIC\PIC_CAL_Float.c
FCD_LCDDisplay0_Command in: C:\Users\Martin\Downloads\DHT11v1.01.c
FCD_LCDDisplay0_ScrollDisplay in: C:\Users\Martin\Downloads\DHT11v1.01.c
FCD_LCDDisplay0_ClearLine in: C:\Users\Martin\Downloads\DHT11v1.01.c
FCD_LCDDisplay0_RAM_Write in: C:\Users\Martin\Downloads\DHT11v1.01.c
Building CASM file
Memory Usage Report
RAM available:2048 bytes, used:73 bytes (3.6%), free:1975 bytes (96.4%),
Heap size:1975 bytes, Heap max single alloc:127 bytes
ROM available:22528 bytes, used:2872 bytes (12.8%), free:19656 bytes (87.2%)
success
Return code = 0
FINISHED
To make life that bit easier, I have converted DHT11v1.01.fcf to work with a lot more devices.
So should work with ECIO40P or a 16F1937 with internal osc or external crystal from 16MHz.
Only way I could think of doing that is to remove timer interrupt altogether and just use delays.
- DHT11v1.01 No timer interrupt.fcf
- (38.91 KiB) Downloaded 897 times
I tried DHT11v1.01 No timer interrupt.fcf, its not working. When I displayed the delay count, it showed 4 .
I also did the above mentioned setting of presacalar ratios and timers in DHT11v1.01.fcf program. It always give checksum error.
My Dht11 is working correctly, I checked it with Arduino microcontroller.
I tried my DHT11 with ECIO40p and I got the humidity and temp displayed OK with the non timer interrupt version.
Are you referring to ECIO-40p Eblock?
I am using the USB programmable microcontroller ECIO 40P. I have connected Dht11 directly through the bread board with the same connections as shown on the the first page. Can you send me the edited program of chip PIC 18F4455? Maybe I made an error somewhere...
Hi paridhi,
To make sure, I have downloadedfrom a couple of posts above.
Changed target to ECIO-40
Re- programmed ECIO-40p and got the following: If you are using with a separate 18F4455 and not ECIO-40p then the clock speed must be 16MHz or above.
If you have modified flowchart, then if you post it I can take a look at it for you.
DHT11v1.01 No timer interrupt.fcfChanged target to ECIO-40
DHT11v1.01 No timer interrupt.fcf shows Delay_count 1. Also the clock speed is 48MHz.
- (1.29 MiB) Downloaded 4442 times
Sorry, I don't know how to make this picture small.
The clock frequency is by default 48MHz. As shown in datsheet.
- (37.5 KiB) Downloaded 12080 times
Confused with that.paridhi wrote:shows Delay_count 1. Also the clock speed is 48MHz.
The flowchart shows :
Delay = 25 Martin
Must be camera angle then.
But A0 should be 4th socket along and looks like nothing in 4th, but red wire in 5th (A1)
Unless GND in in socket 2 in stead of socket 1 of bread board?
Can't tell from pic.
Just going over everything.
What's the colour bands on resistor?
and its A0 only. The pin is working fine. I just tested it. And it is getting signal from DHT11 (tested with led). DHT11 is working fine (also tested).
However, it doesnt Checksum error now. When i remove the wire and connect it again multiple times, it shows Checksum error then.
Ground is blue wire.
It worked, momentraily. I was testing the input provided by DHT11. Just as I removed it from the board, it showed the temp and humidity. Its not working properly due to Breadboard I think.
Thank you, alot.
Sorry, I wasted your time.
Please don't think that.paridhi wrote:Sorry, I wasted your time.
You have not wasted my time at all.
I'm here to help.
Good day to all
Someone could help me to adapt the code for Arduino UNO or NANO or MEGA Thanks
I thought my mistake was wires. But it was the the Delay used in Delay us. It had no value. The warning text was showing during compiling, but since it scrolled upwards, I didn't see it.
So long as all is working.
Re: Measurement of temperature and relative humidity using DHT11
Hi. I'm trying to show the humidity values, read by the DHT11 sensor, on a 7-segment 4-digit display, but I'm not getting it. I was able to display ADC values on the display, but I do not know how to do this for the DHT11. I'm posting the file to the test I did for the ADC. Could anyone modify it for me so that it shows the humidity reading of DHT11?
- Display_7Segments.fcfx
- (11.18 KiB) Downloaded 422 times
- QMESAR
- Has thanked: 384 times
- Been thanked: 614 times
Hi.
It would be better if you post your flowchart that you tried ,people will more easily help with correcting your mistakes as
making the Flowchart for you
Regards QMESAR
Regards QMESAR
I'm posting the flowchart I've assembled so far. I could not progress in the formulas to be able to show the reading of the DHT11 in the display 7 segments of 4 digits. I am a beginner in FlowCode and I am doing a lot of research to try to achieve this.
- 7Segment.JPG (97.09 KiB) Viewed 18943 times
- (10.81 KiB) Downloaded 441 times
I've made a breakthrough. I can already display the numbers in the diplay. Now all I need to do is find out why this odd behavior of the numbers go up to 100 and return to zero as the humidity value increases to the maximum.
- Controle_Umidade.fcfx
- (11.32 KiB) Downloaded 460 times
mnf
- Has thanked: 70 times
- Been thanked: 440 times
You are currently trying to display the humidity - but - the sensor can't be read particularly quickly so I would add a delay to your loop and also just wait until you have a read value before displaying anything.
And the variables need to be changed to floats - you are currently reading a float value into a byte which won't have the result you are after - you would need to use a float to read the humidity and temperature to.
Try something like: - here I got the humidity as a string - but you could also use GetTempWhole etc to avoid the floating point math.
