After managed to get my (Ben´s) RFID reader working I have played with it. I try to add more tag´s/card. I did it my way and I like to share if anybody can use it. I am sure there is a more EASY or CORRECT way to do it, and if, I am very interested to see how to do.
If you want to use it, you can easy see how I have done in the program. I have already 2 card in the att. program.
I have used an I2C display. To read your tag, activate D2 hold the card/tag to the reader and reset the Arduino, and after init you will read the numbers as you can add in the program. After typing the ID in the program, compile and let D2 be low, and you should now e able to use/acces with your card.
Best regard
Jorgen
