ILI9341 after update
A forums to allow bugs and problems with Flowcode v6 to be reported and resolved.
Bachman
Has thanked: 9 times
Been thanked: 53 times
Post by Bachman »
Hello!
Pin "LED" is still in use. If disconneted, got "verbose error" message: "boostc_18F.exe reported error code 1". Portait - landscape problem still exists. Slow update (PIC is running at 64 MHz) problem is still exists.
All the best!
ressi
Been thanked: 14 times
Re: ILI9341 after update
Post by ressi »
Hello. I have the same problem, there is already a solution?
I have now added a Use Backlight property which should allow you to get rid of the backlight pin if your not using it.
I have modified the orientation 3 code now so that this should hopefully sort the text printing the wrong way issue. Other orientations might still have issues.
I will have a look at adding a SPI hardware interface to see if that would help. Probably a number of gLCD components that would benefit from this.
gLCD_ILI9341.fcpx
(7.46 KiB) Downloaded 769 times
Simply copy the above file to your "Flowcode 6/Components" directory and restart Flowcode for the changes to be loaded.
Bachman
Post by Bachman »
Hello!
Better...
Suggestion :wink:
Mr.Tido
Has thanked: 2 times
Been thanked: 2 times
Post by Mr.Tido »
Hello all,
I try to use the same display and it seems to have a problem with displaying a text string or number,
it looks the same way like on the picture from Bachmann, even the numbers are looking very strange.
I can initialise the display and change colors for background and foreground.
I'm using the newest version of Flowcode 6 and also have changed the component file to the latest Benj
has posted here and I'm using a ECIO40P16.
Is there something else to change?
Thank you for any help...
we thought all thoughts,
we said all words,
we just forgot to act.
Please can you attach a picture of your display output and your Flowcode project file and that should help me to pinpoint where the problem is inside the component code.
Mr.Tido
Post by Mr.Tido »
Hi Benj,
here is a picture and the fcfx file and a link to display I use,
https://eckstein-shop.de/22-SPI-TFT-LCD ... 32-ARM-PIC
The Flowcode file just prints two line with text ("Hello World") in different fonts and a number (1234).
But it is not readable on the display, changing colors and drawing some rectangles is no problem.
Test-ILI9341.fcfx
(7.83 KiB) Downloaded 642 times
we said all words,
Thanks for posting your files. Here is an updated component you can try which should hopefully solve the issue for orientation mode 0.
Simply copy the file into your "Flowcode 6/Components" directory before loading Flowcode for the changes to be loaded.
gLCD_ILI9341.fcpx
(7.47 KiB) Downloaded 751 times
Mr.Tido
Post by Mr.Tido »
Hi Benj,
thank you very much for the component file,
it works nearly perfect, problem is that the text is mirrored in orientation mode 0 and 2,
in mode 1 and 3 the text is not mirrored.
orientation mode 0 text is mirrored
looking real good in orientation mode 3
we said all words,
Thanks for letting me know.
Hopefully this should fix the mirroring problem too.
gLCD_ILI9341.fcpx
(7.46 KiB) Downloaded 750 times
Bachman
Post by Bachman »
Hello!
Result of the last update:
(322.52 KiB) Downloaded 1923 times
ILI9341_Geometry_test.fcfx
(7.81 KiB) Downloaded 627 times
