internal oscillator issue
mesut25
Has thanked: 3 times
Post by mesut25 »
Hi all. I am trying to find the correct option in FlowCode 5 for PIC, to set the INTERNAL oscillator for my PIC 16F628A
The flip-flop circuit LED steady
I've tried all the hz
problem ?
Thank you for help
Flowcode1.fcf
(6 KiB) Downloaded 568 times
Re: internal oscillator issue
It looks like the default rate should be 4MHz so your settings look correct.
The problem with your code is there is no delay for when the LED is switched off.
Have you tried a 1 second flasher test?
http://www.flowcode.co.uk/wiki/index.php ... ED_flasher
Also warning your config options have Code Protection and Data EE Protection switched on. Probably not what you want when your starting out or developing new code.
mesut25
Post by mesut25 »
Benj wrote:Hello,
sorun çözüldü :lol: Thank you
